lock tight not holding engine in place >
Old 07-17-2005, 03:44 PM
Default lock tight not holding engine in place
tamyia lock tight is not holding the screws that hold my savage .25s engine
ijust reset the engine again because not 15 min ago to had just moved so this time i put a lot of lock tight and realy tighting it but still move do i have to let it dry
classic xl is offline
Old 07-17-2005, 05:00 PM
Nitro21's Avatar
No you dont have to let it dry before you put the screws back on ,but it wouldnt hurt to clean the threads before applying the locktight.If your locktight has been sitting around awhile shake it to mix it back together.This makes it more effective.And dont use RED locktight or youll have to have a Touch to get the screws out
Nitro21 is offline
Old 07-19-2005, 07:01 AM
Well the Loctite brand 242! you have to let it set 10-15 min
racetruck is offline
Old 07-19-2005, 08:05 PM
Try cleaning out the screw threads and the threads in the engine mount with either soap and water or nitro cleaner. There might be leftover oil keeping the threadlock from working. Tamiya threadlock can take a while to dry since its a sort of gel type. LOCTITE makes great threadlock but there are many different brands as well. just checkout your nearest hardware or automotive store.
Genius is offline
HTML code is On
