servos
hi again people lm very new to this rc l have a monster truck the steering servo is makeing a clicking noise have l got the steering saver screwed down too tight or is the servo on the way out sorry if it seems a stipud question but if l dont arsk l wont know thanks for your help :confused:
The servo making a clicking sound generally means the gears inside the servo are stripped. With the wheels off the ground see if the servo still makes the noise. If the sound only occurs when the steering is at full lock then that means the damage occurred because the servo is trying to turn more and it can't. Either way remove the servo and retest it, you can hold the saver still with your hand to put some load on it. If it still clicks in your hand then gears are stripped inside the servo. You can buy just the gears for many of the servos out there instead of replacing the entire servo. But first take it apart and check for damage to the case particularly where the shafts for the gears sit. If any of the case is damaged it's probably best to just get a new servo. What's the truck and what servo?
its a hsp 94118 redcat l dunno about the server but it was in it when l got it thank s for your reply
IMO the servo is not worth repairing even if the gears are available, just replace it.
ok l gotta replace the servo l would like to get a upgrade one is there any thing l should know before l get one as l know nothing about them thanks
| All times are GMT -7. It is currently 01:11 PM. |
