LST what the heck,,,,,,,,,,,,,,,,,,,, >
Old 07-04-2005, 10:23 PM
Default LST what the heck,,,,,,,,,,,,,,,,,,,,
Okay never had this before but here we go was running my LST today and the tire jsut ran right off the truck pcik it up and the inside of the wheel was strip out and the nut just pulled thought it so if anyone ever had this happen let me know what may have made this happen and I was thinking putting the Proline Hex's on and some new Proline tires and tires anyone ever use them please let me know thanks
Tech_Muggz is offline
Old 07-05-2005, 08:48 AM
Trader Rating: 24 (100%+)
you have to locktite(blue locktite) the wheel nut, regardless of stock wheels or proline's u have to do the same. there is a tremendous amount of vibration from a nitro truck. i have a revo and a mgt that both when i used stock wheels and the new 23mm hexes i have to do the same, locktite. thats the key, otherwise they vibrate lose and then the axle pin will grind on the wheel until the nut is completely off.
vic0280 is offline
Old 07-05-2005, 09:24 AM
mjm
mjm's Avatar
I have a MGT as well. Another option to loctite you can run 2 wheel nuts per wheel.
mjm is offline
HTML code is On
