Sponsored by:
Go Back   R/C Tech Forums > General Forums > Monster Trucks
Old 09-23-2013, 12:34 PM   #1
austinspeer810's Avatar
Default Robinson Racing Gen3 Slipper?
I have an e revo and I saw someone recomending the robinson gen3 slipper clutch upgrade. Is this really worth getting? I see it has metal spur gears which sounds good but are they really better than the plastic? Yes I know they wont strip but what happens if during running the truck if something binds? What would happen to the e revo?
Many people name their cars names...I name my e revo the Dachshund chaser...my neighbors dachshund has never used my lawn for a bathroom since I got it :)
austinspeer810 is offline   Reply With Quote
Old 09-23-2013, 12:42 PM   #2
themanwithnonam's Avatar
If the slipper is correct setup it will be ok.
I can only speak for the savage flux that has a shitty original slipepr setup and there the rr-slipper is good.
Savage XL (for jumping)
Savage Flux XL (for jumping)
Savage Flux XL (for bashing)
Losi eLST XXL
themanwithnonam is offline   Reply With Quote
Old 09-23-2013, 03:13 PM   #3
ckblood05's Avatar
Trader Rating: 15 (100%+)
i have the RRP slipper on my 3.3 t-maxx and i love it! just use a piece of notebook paper and put it between the slipper gear and the clutch bell gear for your mesh.
traxxas t-maxx 3.3 model#4908 hopped up from the ground up!!!!!!!
duratrax 1/18 mini quake 4wd every part is upgraded!!!!!!!!!!
trinity spyder 4wd. 1/18 stock
ckblood05 is offline   Reply With Quote
Old 09-23-2013, 03:23 PM   #4
chadj1980's Avatar
Trader Rating: 32 (100%+)
Its probably the best upgrade you can do...You can actually make the clutch slip and it will last more than a few battery packs unlike the stock setup....Buy it you wont regret it..Last clutch you will buy..
chadj1980 is offline   Reply With Quote
Old 09-23-2013, 03:56 PM   #5
ckblood05's Avatar
i also got the 22t clutch bell by robinson racing. plus i got the whole tranny gear set and front & rear diffs with robinson racing gears! can you say bullet-proof? lol, my t-maxx weighs in at about 14lbs.
Old 09-25-2013, 05:59 PM   #6
rc_collector's Avatar
Trader Rating: 186 (100%+)
totally agree, I got one after my emaxx slipper broke, then got one for all my trucks. it`s the best upgrade you can do.
emaxx.
summit.
savage
rc_collector is offline   Reply With Quote
Old 09-25-2013, 06:09 PM   #7
mydudrevo's Avatar
Did you not read a word I wrote in your other thread?
Proudly sponsored by Tekno R/C
Tekno ET48 CC2200kv/HW150a
mydudrevo is offline   Reply With Quote
Old 09-25-2013, 06:11 PM   #8
mydudrevo's Avatar
You have created 138 new threads and you only have 318 posts thats almost half stop posting new threads on the same truck you can ask all of these questions in the threads you've already started or the appropriate section for your truck
Old 09-26-2013, 01:29 AM   #9
The gen 3 is very nice, I recommend saving yourself the down time and buy any pinion you might want to run in hardened steel for it, other pinions won't last. Found it much easier to set my mesh by sound rather than by paper ( and I use paper for everything ) My gen 3 was happiest just a little further away from pinion than setting it with paper left it at
Dave_S is offline   Reply With Quote
Old 09-26-2013, 04:10 AM   #10
spookie's Avatar
Trader Rating: 25 (100%+)
I found that to be true on my RR spurs also. My son burned up four titans in a week, setting it where he thought it should go, per specs. When he went BL, I made him bring it by here and I set it to be sure he didn't have it too tight, which he did. Yep, when it's right, it's a nice sound, when it's wrong, it sounds awful.
spookie is offline   Reply With Quote
Old 09-26-2013, 08:39 AM   #11
Ditto on the RRP Gen3. I've got one in my E-Maxx and it's the only thing that holds up to that big 2-Pole.
And absolutely get hardened pinions. It will eat everything else.
TRX E-Maxx - KD 2039kv/HW 150A | TRX Summit - DeWalt 14.4v/TRX EVX2
TRX Slashapede 4x4 - Vel. 3500/HW SC-8 | TRX Stampede 4x4 - Vel. 3500/BL Hobbies 120A
TRX Slash 4x4 Ult. - HS 3500kv/HW SC-8 | Losi E-Muggy - Leopard 2000kv/HW 150A
Tam. Stad. Blitzer - KT 19T/HW 1060 | Ofna Ultra LX2-E - TP 2400kv/HW SC-8
WindDrake is offline   Reply With Quote
Old 09-26-2013, 08:56 AM   #12
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Not needed IMO , adjust the stocker correctly and you will be OK ....
Have you been ripped off by Brushless Hobbies ? If so go to BBB.org and file a complaint !
BashemSmashem is offline   Reply With Quote
Old 10-05-2013, 02:38 PM   #13
I just installed this piece in my summit. 2 questions:
Which side goes the curved washers ? (((( or this side )))) ? Considering that left is the spur gear ? I set up )))) since IMO the nut pushes in the washers towards the spur gear.
Also how do tighten the nut ? All the way and a quarter off like the stock setup?
Thanks !
LCM94 is offline   Reply With Quote
HTML code is On
