Stamped 1/8 conversion help
So now that I have converted my Savage to an XL flux, it's time for my
next project. I'm looking into converting my 2wd Stampede into the 1/8 version. when looking online, I see people are using the FLM 1/8 chassis. Now here is where I need help: on you tube, I saw that a guy is using Jato Arms is this the way to go? I see that FLM offers and front arm 1/8 conversion but not for the back? I'm confused. Honestly, I prefer not to ever use Aluminum Arms, only chassis and shock towers: Can someone please give me some input on what are the best parts to use for this conversion and part #s please. Thanks as always. |
FLM may not offer the wide arm conversion for the rear because you can just use a wide offset wheel. The front already uses a wide offset wheel and can't get an wider that way.
I'm not familiar with the Jato conversion but I can see how that would work. The other way to widen the front is to use the Pede's rear arms up front. I did this once years ago, not much to it but I think you need a new longer camber link in addition to the longer steering link. Jang over at URC has great documentation on the mod and may have been one of the first to do it. Just google Stampede wide arm conversion or see the Jang's here. http://www.ultimatetraxxas.com/proje...ede/phase2.php http://www.ultimatetraxxas.com/misc/...pede-wide-mod/ Edit: For the chassis it is pretty easy to lengthen the stock one with some flat aluminum or angles that you can get at a hardware store for under $10. Another easy way to go bigger is switching to a Slash chassis, just cut the sides off if you need to. Pretty sure all you'd need is the chassis, steerin bellcrank and the front skid/chassis brace, you have everything else. |
| All times are GMT -7. It is currently 12:44 PM. |
