Sponsored by:
Go Back   R/C Tech Forums > General Forums > Monster Trucks
Old 09-13-2013, 12:24 AM   #1
fester's Avatar
Default Stampede motor issue?
Hi i have a traxxas stampede xl 5. I am running a venom 17t fireball motor, well that went so i was gonna throw in a tamiya 540 silver can motor my problem is the shaft where the pinion sits is too short i tried puuting the pinion on both eays but ot dont mesh up right with the slipper clutch gear? I am running the stock pinion that ce with the truck?
Any ideas?
fester is offline   Reply With Quote
Old 09-13-2013, 05:34 AM   #2
Trader Rating: 24 (100%+)
You could find a pinion with a wider shaft base or you can toss that motor back up on the shelf and put a different motor in the truck.
.......__________________
....../_==o;;;;;;;;__ _____]
.....), ---.(_(__)
....//___// Support NRA!
got_nitro is offline   Reply With Quote
Old 09-13-2013, 12:32 PM   #3
fester's Avatar
Yeah i am gonna have to order a new motor. I have nothing else to put in there
Old 09-13-2013, 01:38 PM   #4
1967Typhoon's Avatar
Trader Rating: 34 (100%+)
I like the HPI Firebolt 15T motors. They are equally as fast as the Titan, and seem to last longer. Just break them in at 1/4th throttle for the first 5-10 minutes. They are cheaper than the Titan as well, at around $15 shipped all over the web.
EDIT - only $13!!! http://www.ebay.com/itm/HPI-Racing-1...item1c36762251
SCX10 II Kit (in progress)
Traxxas E-Revo Brushless Edition / HPI Blitz 1/8 Buggy Conversion
Associated TC4 Rally Conversion / Losi Micro SCT
1967Typhoon is offline   Reply With Quote
Old 09-13-2013, 06:15 PM   #5
ThePanda's Avatar
Trader Rating: 65 (100%+)
Yes the firebolt motor is quite nice. One came in the sprint 2 that I got for shitz and giggles. Nicely torquey with good speed. I do think the breaking power was a bit lacking
ThePanda is offline   Reply With Quote
Old 09-14-2013, 01:47 AM   #6
fester's Avatar
Thanks guys. I had a titan in my other pede in which i burnt it out in 2 battery packs i will look into the firebolt motor ty
Old 09-14-2013, 06:22 PM   #7
Send a message via Skype™ to k-weaver
Spend a little extra and get a rebuildable motor. That way you can replace brushes and not cans. Just my .02
k-weaver is offline   Reply With Quote
Old 09-14-2013, 08:38 PM   #8
meno1103's Avatar
I'm not sure a rebuildable motor would help here, burning a titan up in 2 packs is a little odd. Can motors are usually more heat forgiving, although they have less ouput, so if you wore the brushes out, I'd look into your gearing. If you're running stock gearing, you most likely need to gear down (smaller pinion).
HPI RS4 Rally/Pro/Nitro 2's, Traxxas Big Block Npede/Slash 4x4/Nitro 4-tec/E-maxx, Ofna JL10e, Kyosho Inferno GT2, Exotek R18II
Umm, what does overkill mean again?
meno1103 is offline   Reply With Quote
Old 09-15-2013, 11:19 AM   #9
fester's Avatar
I am still running the stock pinion n gear setup As iit came from the factory. I.cant complain i got a few years use out of the fireball motor. Thanks
Old 09-15-2013, 11:54 AM   #10
try a flysky s600 motor, very hard to kill motor, and you can also gear it up a bit cause it runs cooler.. under $20 on ebay.
Flux4.6version is offline   Reply With Quote
HTML code is On
