Sponsored by:
Go Back   R/C Tech Forums > General Forums > Monster Trucks
Old 09-25-2013, 04:29 AM   #31
spookie's Avatar
Trader Rating: 25 (100%+)
Originally Posted by fr8cture View Post
Kinda off topic now but Got_Nitro has been doing that ever since I joined the forum in January..
Doing what?
spookie is offline   Reply With Quote
Old 09-25-2013, 04:45 AM   #32
ThePanda's Avatar
Trader Rating: 65 (100%+)
Originally Posted by spookie View Post
Doing what?
Acting up.
ThePanda is online now   Reply With Quote
Old 09-25-2013, 05:07 AM   #33
spookie's Avatar
Originally Posted by ThePanda View Post
Acting up.
Oh lol thanks. Well, some forum members are assets and some, not so much lol. Sorry. back on topic.
Old 09-25-2013, 11:52 AM   #34
austinspeer810's Avatar
Any aluminum parts that people recommend? I was looking at upgrading the drive shafts on my e revo to the nicer metal ones instead of the plastic ones but I hear people have broke them easily too. Are these really that good or would the plastic ones be fine? Also does your truck look like it is going slower than it claims it goes? I had an 18/54 gearing and it didnt look like it was going as fast as I thought it was going. maybe it is just me overthinking the speed
Many people name their cars names...I name my e revo the Dachshund chaser...my neighbors dachshund has never used my lawn for a bathroom since I got it :)
austinspeer810 is offline   Reply With Quote
Old 09-25-2013, 12:02 PM   #35
lbenton's Avatar
Trader Rating: 48 (100%+)
I think that upgrading the spinning parts to metal can improve things. But doing the "bling" route is not going to make it rougher or tougher. RPM upgrades work well for arms / body post / skids / bumpers / etc. and being able to flex they will take a beating and still be there for you. Often the stock plastic can crack or break and aluminum will bend or simply transfer the energy of impact back to some other point in the truck snapping off parts.
I would also very much recommend the 17mm hubs, they will hold up much better than the 14mm ones under brushless power. The splined hubs are a step up to that putting more surface area into play. Larger than 17mm only limits your buying options without giving you any real advantage.
lbenton is offline   Reply With Quote
Old 09-25-2013, 01:33 PM   #36
ThePanda's Avatar
the ability to run 17 mm hex wheels is a big plus.
Old 09-26-2013, 08:41 AM   #37
Originally Posted by mydudrevo View Post
Yep although some people just want to dump money into their rigs. They want nice new cool looking parts. I want simple and works lol i put this out on traxxas forums like a year and a half ago and a bunch of people just replied "just get the Robinson racing slipper it's so much better" I for one can honestly say ITS NOT!! Do this and be done with melting spurs and glazed pads. Also another tip for new guys DON'T GET A STEEL SPUR GEAR! This is something I wish someone would have told me when I was younger because I put steel spurs on all my cars when I first got started but they are terrible. Your car needs a point of failure somewhere let it be the $3 spur. And I haven't scredded a plastic spur in any of cars in years I replace them every now and then just because of wear but they never strip and only need to be changed like once a year.
On most trucks this is a sure thing, but the Maxx and Revo lines really benefit from things like the RRP Gen3 steel slipper/spur combo, as the original factory assembly was designed for Brushed motors, and will just detonate under any setting that holds BL down.
TRX E-Maxx - KD 2039kv/HW 150A | TRX Summit - DeWalt 14.4v/TRX EVX2
TRX Slashapede 4x4 - Vel. 3500/HW SC-8 | TRX Stampede 4x4 - Vel. 3500/BL Hobbies 120A
TRX Slash 4x4 Ult. - HS 3500kv/HW SC-8 | Losi E-Muggy - Leopard 2000kv/HW 150A
Tam. Stad. Blitzer - KT 19T/HW 1060 | Ofna Ultra LX2-E - TP 2400kv/HW SC-8
WindDrake is offline   Reply With Quote
Old 09-26-2013, 08:53 AM   #38
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
IMO you should stay with the plastic driveshafts as the metal ones will bend if you run it hard . Also I see no need for a steel spur or the RRP slipper as long as you make sure the stocker isnt locked down and is working .
As I stated earlier RPM a arms , Lunsford Ti turnbuckles/toe links , and the M2C rear pin block and you are pretty much good to go . Maybe get one of those rear chassis braces if you think youre gonna bash hard .....
Have you been ripped off by Brushless Hobbies ? If so go to BBB.org and file a complaint !
BashemSmashem is offline   Reply With Quote
Old 09-26-2013, 10:54 AM   #39
mydudrevo's Avatar
I have 3 nitro revos, 1 tmaxx, and an erbe with lst2 diffs that only runs on 6s and All my Nitros run big blocks and if you do the tmaxx brake disc like I put in my previous post you will never have a problem. The steel spur and pinion create way to much heat and kill bearings I had the rep slipper now I do my tmaxx pad slipper mod and have no problems
Proudly sponsored by Tekno R/C
Tekno ET48 CC2200kv/HW150a
mydudrevo is offline   Reply With Quote
Old 09-26-2013, 11:35 AM   #40
I'll agree with the T-Maxx Brake Disc mod. That's a good alternative. However, I was originally talking about the as-provided slipper, which is still a pile of junk unmodified.
However, 2 years and counting on my RRP Gen3 in my E-Maxx, no issues. Most of your metal-on-metal bearing killers come from bad meshes and slop. Nitro may also have an issue with all the rotating mass added by the considerably heavier steel slipper/spur combo.
HTML code is On
