eLST XXL build
eLST XXL build
Hello,
so finally parts arrived for my eLST build and I got me some free time to start the build. What I've seen from my two flux rigs is that they really benefit from having a CD, over a tranny.
I currently running my flux on 6s with 48/10 gearing using gt or terrapin tires.
As I'm planning on to run smaller and lighter tires on this build I will probably use 48/11 gearing.
At hand I got a 50t and a 60t spur a full range (9-20t) of pinions to experiment if needed.
I ordered almost all parts from dollarhobbyz, but beside the standard parts I also ordered a:
castle 2200kv motor
mamba monster 2 from tower
set of 4 losi 3.2 1/2" offset dish wheels from a main hobbies
hpi vorza CD
a proline topkick body
a hpi ford f150 supercab body
a set of proline 40 series crime fighters
a set (2) of turnigy 5.6A 2s batts
a set of 40 series velocity rims
a set of 17mm hexes
Some parts
As Losi is all new to me this was a mess and I had the exploded views printed so I could start the assembly. I wanted to quickly get an idea on how the layout could be
Well, that's all for now folks...
castle 2200kv motor
hpi vorza CD
a set of 17mm hexes
Some parts
More layout
Thank you guys. This build will not use any fancy parts or so, the focus is more on the brushless setup and CD.
Anyway after the assembly and just trying out different layouts - moving batteries, motor and esc around on the plate I decided that I want the motor down low side to side to the CD.
Some metal had to go - lazy style
I also made a new temporary bottom plate. Later I will perhaps make a new when I know what the looks of it should be.
The planned layout is now something like this
Single servo
I tried to find some info on using a single servo setup. It would allow to offset the CD instead of the motor. I see that kimbrough has some large heavy duty servo saver. Anyone tried one of those?
http://kimbroughracingproducts.com/s...oduct_id=29908
I only heard of ONE muggy in a Swedish forum, I don't think there exists many of them here.
Besides it's more fun doing things this way
Team Durango 60t spur
Here's a closer look at the 60t spur I have. It's from a dex408 team durango.
I figured I could use it to have more gearing options but it is just too big.
It's a direct drop in the hpi vorza CD
You'll probably have a hard time finding cvd's / dogbones to suit. Not saying it can't be done, just a pita.
Finally, if I can't get the tekno one to fit I will just cut and weld the originals...
Currently I'm just waiting for parts. I had to order some stuff, because I first tried to fabricate my own motor mount outta aluminium, and well, it works but it looks so damn ugly. The mill I have is china made and in fact almost only good for drilling...
So for motor mount I ordered a Ofna Ultra lx2e motor mount + CD mount.
Think I will ned some 19mm bearing for my hpi CD to make it fit.
I'm also waiting for some standard servos. But later I will probably buy a strong single servo.
How long do you need?
I have never had an xxl chassis but IIRC the diff can be placed central with lst/aftershock axles front and rear. I say lst1 because the cvd end is smaller than lst2 and fits right into the cvd cup on the diff pinion. They are about 140mm.
If you need longer than what you have mentioned how's 182mm... http://www.hobbystores.co.uk/default...-020-050,b:XTM
I think the tekno one has good length and I ordered, so firstly I will wait and see how that goes. The XTM one might in fact be too long
Thanks for the suggestion
Ok, not so much news here, still wating for parts, especially the motor mount and center shafts.
Did get some parts in (sorry for the bad pics)
40 series velocity and 420 force wheels. The 40 series on cen 23mm hexes in fact add extra +5mm width over stock wheels. The cen hexes are a really tight fit and removes almost all slop.
I always liked the wide look that 40 series gives
I also got these traxxas repsonse pros today to try out. HAd some great fun with my flux today on asphalt so I will probably get some road rages 40 series fro the force wheels later.
