Question, need some help
I have several revos, a 2.5, 2.5r and a 3.3. I just put a header on the 3.3 that has a spring instead of the screws since it is such a pain to remove with the screws. I left the little orange rubber washer on the motor and added the black washer that came with the header. Seems like I have an air leak now with the set up. When I am on the throttle and let off the motor revs up then goes to idle. I know this is an indication of slight lean and think it may be from the header. Has any one else added this style header with the same issues?
I put a small hose on the stinger of the exhaust and blew in. There is a TON of air coming out where the header meets the head. I am do something wrong with the install of the header/spring mount??
How loose or tight does the header fit on the exhaust port of the motor? I ask because most spring headers I've seen are kind of universal fit and use a double seal exhaust gasket and would fit very loosely on a Traxxas engine that was only using an o-ring. Traxxas O-ring forms a seal on the inside of the header, while typical exhaust gaskets also seal the face of the header, two sealing surfaces.
The link shows a typical exhaust gasket with double sealing surface. http://www.amainhobbies.com/product_...e-Seal-Round-2 |
Originally Posted by Overdriven
(Post 12398216)
The link shows a typical exhaust gasket with double sealing surface. http://www.amainhobbies.com/product_...e-Seal-Round-2 I know there is an issue as I destroyed my 3.3 engine last week with this header. The connecting rod SPLIT right down the middle. I had to get another engine for it. |
Originally Posted by jayman69
(Post 12398233)
It seems fairly loose.....not sure how the setup is able to seal.. Those in the link however seem like they would be MUCH better. I wonder if I could get those to work on the revo.
I know there is an issue as I destroyed my 3.3 engine last week with this header. The connecting rod SPLIT right down the middle. I had to get another engine for it. What happens is the pistons wrist pin is slapping down on the rod from pre-det before the crank pushes the rod to TDC. Lots of stress for a traxxsucks engine! That and the rod's in those engines are recycled cheap aluminum that are used in the traxxsucks 2.5 engines as well, doesn't help any. |
Not sure about other failures but this one was my fault. It was after the new header and the truck seemed so much faster. I was chasing the lean condition knowing it was not right. No matter how much fuel I gave it, it just seemed to get leaner...... Once it shut off I hit it with the temp gun and it was 298*.
Running 20% fuel with the right plug. 99% sure it was the exhaust header that led to my problem |
| All times are GMT -7. It is currently 11:36 AM. |
