Decided to convert to 1/5 scale. :)
#16
no prob. All my info is from those who have gone before lol. Did alot of reading up to get the info I needed myself. The big thing from what people say is being able to get the right gearing for the setup you are using. The motor they include, the 2200Kv on 6S can be pushing it in my opinion personally. You probably would want a larger spur gear so you can use that in combo with a smaller pinion to get a better gearing range. Or, as I and others have done go with a motor that has lower Kv, preferrably with a longer can. Castle 1518 motor comes to mind for one. That is what my vehicle came with initially before trading it to a buddy and getting the Castle 1600Kv 1520 motor that from what I recall, has a can as long as the XO-1 motor.
And, a lot of the temps you will see will depend on what you plan to use the vehicle for. Are you lots of high speed action or slower driving, etc.
Me, I am thinking of making this more of a glorified rock racer or something to rumble over stuff with, so going with 4S setup on the same motor versus the 6S.
I'm thinking 14 or 15t pinion, with the oversize 7"+ tires I will have to go down lower than that probably. I also have to worry about grenading the drivetrain(still running the 3speed tranny) locked into 3rd of course, How do I tell if the diffs are upgraded, there is almost zero slop in the ring and pinion and the front diff is an alloy of some sort, but I don't know if that was stock on the savage x ss 4.6 (And to answer a previous ? I am running extended axles with the purple spacers.)
#17
Tech Legend
I think I will use these batteries for now, just dial down the throttle and gearing down to where I only get around 27 or so mph( keeping my temps down) my gearing is pretty much as high as I can get I'm running an idler mount with a 21t pinion with a 52t spur lol
I highly recommend you look into the bearing mod I mentioned when using the extended axles. All you have to do is find bearing similar in dimensions (I used 2 bearings to represent 1 spacer). The bearings were big in outer diameter, but the width and inner diameter were good to go. I believe they were roller bearings for blinds?
#18
Don't know about the diffs, never messed with the nitro versions, this one was actually my first savage lol.
#19
I see what you mean more surface area for the adapter to back up too instead of that 1 to 2 mm thick spacer. I see now, if I don't use a bearing I will definitely upgrade that now that I think of it that seems it would be a weak link.
thanks for the info on that
#22
Tech Legend
If you mean the trays, I did with the dual 3S lipos I had, but they woudl fit down the middle just fine. Originally I was going to use a separate receiver pack to power the servos (was going to do a dual servo setup), I still may. just need to decide where to put it lol.
#23
I want to convert mine to 1/5 but the bodies and tire/wheels are expensive!!!
