AE Green Slime VS Losi Blue Great Grease VS Losi High-Pressure Black Grease >
Old 03-25-2013, 03:11 PM
bigbadbasher's Avatar
Default AE Green Slime VS Losi Blue Great Grease VS Losi High-Pressure Black Grease
Anybody used all of these? I am wanting to get one to seal up my carb needles ect. ect... Ive heard GREAT things about the AE Green Slime..
bigbadbasher is offline
Old 03-25-2013, 05:32 PM
Trader Rating: 38 (100%+)
I use green slime to build shocks, use silicone to seal up your engine
vw addict is offline
Old 03-25-2013, 05:45 PM
Im not going to use silicone on my carb needles..
Old 03-25-2013, 05:50 PM
Cinnabun's Avatar
Trader Rating: 24 (100%+)
I always used green slime on my carb needle o rings. It sealed them up, and made the needles much smoother to turn. I also use it for shock o rings, diff o rings, pretty much any O ring that needs lube.
Cinnabun is offline
Old 03-25-2013, 06:19 PM
Thats what i was thinking.. You like the green slime? I wonder what it's made of..
Old 03-25-2013, 06:25 PM
Cinnabun's Avatar
Yes, I love that stuff. It's just a silicone based lubricant.
I've also used Vaseline on carb needles with good results.
You can get a much better deal on green slime by going to a local bike shop and asking to Noleen sf-3, its a fork seal lube. You can use any fork seal lube, there is also a produce called sticky honey which is the same thing. The above are about the same price as a tube if green slime, and you get about 10x more. That is what I use now.
Cinnabun is offline
Old 03-25-2013, 06:41 PM
Thats exactly the info i was looking for, i was wondering what it really was, im sure it's used for more things but Fork Grease is probably primary, i think Yamaha makes some, so does Diawa for fishing reels....
Old 03-25-2013, 06:47 PM
I also wonder if it would be ok to use as a lube for the little bearings in my LST2 slipper?
Old 03-25-2013, 06:52 PM
Cinnabun's Avatar
The only problem I see with reel grease, is some have polishing compounds in them to keep the gears and surfaces corrosion free and clean. Though you won't be turning the needles enough for that to matter, I figured I would toss in that fun fact for the night.
Cinnabun is offline
Old 03-25-2013, 07:33 PM
That is true, i know the greases for salt water have those compounds not sure if they are rough on the metal though..
HTML code is On
