clodbuster???
Old 05-02-2005, 01:19 PM
Default clodbuster???
any of you have the old clodbuster or even the new super clod. if so i was cleaning my old one and forgot to write down which wires go to the speed control and switch. if anybody could send me a pic that would be great. and i already tried tamiyas wevsite and it didnt show where they went.
rangered is offline
Old 05-02-2005, 04:18 PM
NVisible's Avatar
on the mech speed conrol? damn son you need to get with the times
check www.tamiyaclub.com they have online manuals you can look out
NVisible is offline
Old 05-03-2005, 12:59 AM
Default hi
so theres electonic speed controls for it??
rangered is offline
Old 05-03-2005, 02:40 AM
pininfarina's Avatar
Trader Rating: 16 (100%+)
for twin motors... you can use ESC such as novak's super rooaster.... 6 - 10 cells I think... or the Super Duty XR ... 6 -14 cells...
url here
pininfarina is offline
Old 05-03-2005, 06:24 AM
4wdmt's Avatar
definitely go for the ESC. your clod will run much smoother, your battery pack juice will be used up more efficiently. its a number 1 upgrade to your r/c, then BBs.
4wdmt is offline
Old 05-05-2005, 10:19 PM
Default hi
do you have to have a reverse roatation motor for these. or can you just plug it reverse into the speed control so that one motor is reverse and one is forward
rangered is offline
Old 05-05-2005, 11:28 PM
4wdmt's Avatar
if you are using stock silver cans (which have o degree timing), just plug it in reverse. but if its a modified motor with adjustable endbell, better rotate it 180deg. kyosho mag mayhems have a reverse rotation available. but for me, i the silver cans are enough to play around.
this is a good link for dual motor application intended for clodbuster. very simple instruction with good pics as well:
http://www.ds411.com/utrcrc/tech.html
hope it helps.
4wdmt is offline
Old 05-06-2005, 12:55 AM
thanks for the site... found it interesting
Old 05-08-2005, 12:12 AM
4wdmt's Avatar
yeah, the site is very useful. i used their tech. tips on motor wiring to my integy 55T lathe motor / SR combo. Then, i used their tips on how to narrow the tires. with the illustrations and notes, its easy.
4wdmt is offline
HTML code is On
