Need Help for BULLET ST 3.0 Electric Conversion >
Old 02-10-2013, 07:16 PM
  #16
roniehan's Avatar
I ask around in the msuk-forum and lots of Bullet owner is using stronger servo to improve the steering problem, so last Saturday I tried to take out my savox 1256 20KG from my RC8E and put it in my Bullet and apparently it solved the steering issue.
But I cant seem to find a perfect match to upgrade the steering with the alloy one, so sad....
roniehan is offline
Old 02-12-2013, 12:16 AM
  #17
roniehan's Avatar
But a friendly reminder, be careful of using Savox with your receiver, I would highly recommend of getting the Spektrum voltage protector with your Spektrum receiver. It is cheap and does the job pretty decent.
roniehan is offline
Old 02-22-2013, 11:43 PM
  #18
roniehan's Avatar
UPDATED 23 FEB 2013
Just installed the Wheelie Bar from HPI Savage.
Combo MMM + Turnigy Trackstar and steering servo will be Savox 1256TG
roniehan is offline
Old 02-27-2013, 06:07 PM
  #19
roniehan's Avatar
UPDATE 28 FEB 2013 100% DONE
Now I consider my Bullet Project is 100% done after I improved the steering horn using the steering horn from my Hyper9 and some rod end with some kind of ball with longer screw 3x26mm.
-Bullet ST 3.0 converted to Electric
-Mamba Monster ESC
-Turnigy Trackstar 2650kv motor
-Savox 1256 TG 20KG/6v servo
-4S capable battery with battery tray
-Improve steering horn and linkage
-All Rod end replacement
-CNC C-hub and steering knuckle
-Front universal drive shaft
-A pair Bullet MT wheel and tires
-Savage XL Wheelie Bar
roniehan is offline
HTML code is On
