my losi lst
Old 04-11-2005, 02:07 PM
maddog0118's Avatar
Default my losi lst
now makes a grinding noise from the back.....makes like a scrunching noise.....mainly when i speed up the car...the faster it goes the louder the scrunching noise......so i need a little help.....
maddog0118 is offline
Old 04-12-2005, 01:27 PM
could be a rock inside the two spur gears...either that or the ring and pinion in the diff.
LostAggie is offline
Old 04-13-2005, 08:57 PM
Check your diff cases to make sure they're not broken. If they are, you should be able to see the crack in the to of the case. This will allow for some play in the gears whicih can cause noise and eventual destruction of the gears.
I'd strongly recommend getting Losi's aluminum cases to eliminate this problem or to prevent it from happening in the future. They're only $10 each.
doesgo is offline
Old 04-14-2005, 02:19 AM
maddog0118's Avatar
Default ty
for all your help//
learning rc is tough
HTML code is On
