-   Monster Trucks (https://www.rctech.net/forum/monster-trucks-46/)
-   -   Silicon engine coupling keeps breaking (https://www.rctech.net/forum/monster-trucks/683201-silicon-engine-coupling-keeps-breaking.html)
Dubai201010 12-02-2012 10:44 AM
I am new to this sport. I have a hpi pulse and since i got it last week, the exhaust coupling which is made of silicone broke 3 times already and i had to get it changed. The plastic brackets kept melting, so i put iron hose clamps which didnt really help. Can anyone please help me and give me some advice what i should do, am tired of going to the model Shop.
imaxx21 12-02-2012 02:01 PM
sounds like you need a one piece pipe
R/C Lidz 12-02-2012 02:05 PM
if your pipe and manifold are both properly secured there shouldn't be any stress on the coupling at all. Check the manifold spring and pipe spring/support (at the front of the pipe).
mtpocketsracing 12-02-2012 02:26 PM
or quit using the hpi one.
Dubai201010 12-03-2012 03:36 AM
thanks for your reply, were can i find a one piece pipe? how do i know whats the diameter for the engine connecting part. sorry about my amateur language but just started this hobby so am slowly getting used to things.
Dubai201010 12-03-2012 03:38 AM
thanks for your reply. it seems the spring is pretty tight which holds the exhaust on the engine, the spring looks like its cutting into the metal of the exhaust outlet :confused: really dont know how this silicone connector can break for a third time. maybe the metal hose clamps were too tight :s
Dubai201010 12-03-2012 03:39 AM
what alternative to you recommend? have you had this problem before with your hpi?
banana rt 12-03-2012 06:42 AM
check ur pipe hanger at your chassis, make sure your pipe sets exactly straight. use appropriate springs, and use good silicone. many good pipe out there, OS, Nova, but for basher any pipe works good.
good luck
scwrod 12-03-2012 07:32 AM
maybe less of a gap between the muffler and the header.
Boinker 12-03-2012 08:08 PM
To recommend a good pipe for just about any situation the ofna 086 is a great solution.
http://www.nitrohouse.com/OFNA-086-P...e_p_14090.html
Get a few extra gaskets and springs for the engine and manifold while you are there. Just in case right.
http://www.nitrohouse.com/18-Scale-E...t_p_13663.html
This will also change the tune of the engine and likely get you some more power. the 086 is an all around pipe more focused on the mid range so for whatever you do with the buggy you will like it.
My thought, Boinker.
Bansh88 12-04-2012 02:08 PM
Some of those couplers are pretty soft. Especially if by chance this is on an older used car.
Try a piece of radiator type automotive hose. This would just be a quick fix. If it keeps breaking, something is not right.
got_nitro 12-04-2012 04:48 PM
There is no way that piece can keep breaking unless something is loose or rubbing on it. Even if the spring was weak and did not hold the header to the exhaust port tight and let it turn, the silicone is dense enough to hold the header in place as long as the pipe is mounted to the chassis up front properly. Can you post up some pics of the broken silicon pieces?
