-   Monster Trucks (https://www.rctech.net/forum/monster-trucks-46/)
-   -   Electric Conversion (https://www.rctech.net/forum/monster-trucks/666250-electric-conversion.html)
figanator 09-30-2012 08:38 PM
Electric Conversion
My friend has a tmaxx 2.5 and I have a emaxx with dual kershaw engines. I've got a brushless setup on a whole other transmission. My friends wanting to go electric. Can we just drop the trans into his?
rustlererad3 10-01-2012 06:51 AM
Well as you know your gonna need to remove all the nitro gunk off the truck and if your gonna change the transmission and all I would think it should bolt up but you also need to configure a system for mounting the batteries in the truck as well
Overdriven 10-01-2012 11:28 PM
If the extra trans you have is a 3906 trans then yes it will bolt into the 2.5 chassis. If you have the newer 3905 trans then no it will not bolt into a 2.5 truck. 3905 trans is a little too wide and the bolt pattern is different and uses 4mm screws instead of the 3mm on the older style.
mongdex 10-02-2012 06:53 AM
http://www.rctech.net/forum/monster-...ed-t-maxx.html
rustlererad3 10-02-2012 08:31 AM
So I'm curious to know what became of this project
