help pls! Pro. 15 ez start to pull starter > help pls! Pro. 15 ez start to pull starter
Old 02-21-2005, 06:23 AM
Default help pls! Pro. 15 ez start to pull starter
Hi everyone just need some help restoring my old T-maxx with a pro .15 engine. For some reason the one way bearing keeps slipping but that seems to be a common weak point with this model, aside from that I'd like to change ez start to a pull starter to save weight. Anyways, my question is what do i need to convert my pro .15 engine to a pull starter? any feedback would be great. thanks
Genius is offline
Old 02-22-2005, 07:01 AM
never lift's Avatar
new oneway bearing and the pullstarter that's all you can modify the 2.5 oneway to fit
never lift is offline
Old 02-22-2005, 07:42 AM
Regional Moderator
nitrous36's Avatar
You can buy a pro 15 pullstarter. Remove the ezstarter assembly from the backplate and the pullstarter should mount right up.
nitrous36 is offline
Old 02-24-2005, 06:47 PM
THANKS!! thats exactly what i needed to know.
Genius is offline
HTML code is On
