hpi savage transmission help needed >
Old 06-04-2012, 06:52 PM
Default hpi savage transmission help needed
my savage will not go into gear it is a new transmission. is there any adjustment i can make to the transmission at full throttel it just barley turns the tires
denteddodge_76 is offline
Old 06-04-2012, 07:30 PM
Well if youre at full throttle and barely turning the tires makes sure no gears are stripped and your teansmission and drive shafts are hooked up correctly......... And also yes there's a way tune it
Is it a 2 speed or 3?
If you have a manual for the savage read that cause it shows you how and where to adjust the tranny
Bmk10 is offline
Old 06-04-2012, 07:38 PM
no gears are striped. i was wondering if you could adjust the clutch in side the transmission
Old 06-04-2012, 07:54 PM
it is a 2 speed
Old 06-04-2012, 08:19 PM
OS21Revo's Avatar
check your slipper, sounds like its loose or maybe the slipper clutch hub pin is missing. The adjustment on the side of the trans is for how fast it shifts.
OS21Revo is offline
Old 06-04-2012, 08:21 PM
bobbyblaze's Avatar
is you engine tuned? if you engine running rich the car will not shift
bobbyblaze is offline
Old 06-04-2012, 09:19 PM
it is tuned fine it just will not go any where. The slipper sorry where is that? I am about to go just buy new.
Old 06-05-2012, 01:29 AM
Trader Rating: 30 (100%+)
There is a nut and spring on the end of the shaft that holds your spur gear. That is where you adjust your slipper tension. The slipper is there to protect your drivetrain from sudden jolts, like if you land a jump while on full throttle. It can be a good tool for tuning your take-offs if you are in low-traction racing situations. For general bashing, i'd just lock it down.
On my Savage, I use a small 4-way wrench or needle nose pliers to hold the nut, then turn the spur gear counter-clockwise by hand until I can't get it to turn anymore. You should feel it getting tighter until you can't turn it anymore.
sdtech58 is offline
HTML code is On
