-   Monster Trucks (https://www.rctech.net/forum/monster-trucks-46/)
-   -   t maxx rebuild problem. please help (https://www.rctech.net/forum/monster-trucks/593243-t-maxx-rebuild-problem-please-help.html)
jon perry 01-30-2012 01:51 AM
i have been using my new t maxx and got it really muddy
so i took all apart cleaned and oiled everthying that needed it but and i have put it back together
it looks fine but there is a big problem, when i push the front wheels forwards the rear wheels goe backwards and vice versa. so i will not start the engine because the wheels are fighting each other
also the slipper clutch pads have been changed and the slipper clutch does not not move when the wheels spin.
where have i gone wrong!
SloRacer1080 01-30-2012 02:16 AM
One of your diffs are in backwards. Either the front or rear diff needs to be flipped over, depending on which way you installed them.
jon perry 01-30-2012 03:42 AM
how do i know which one is the wrong way around
dug44 01-30-2012 03:58 AM
http://traxxas.com/sites/default/fil...ear-2008_0.pdf
http://traxxas.com/sites/default/fil...ont-2008_0.pdf
SloRacer1080 01-30-2012 03:59 AM
This is the back diff, looking at it from the rear of the truck...
http://i443.photobucket.com/albums/q...130_070724.jpg
And this is the front one, same angle, looking towards the front of the truck...
http://i443.photobucket.com/albums/q...130_070703.jpg
A bit blurry, but thats my phone in night mode.
jon perry 01-30-2012 10:28 AM
ok thanks
i will have a go
Cadimman 01-30-2012 10:31 AM
Raise the truck and rotate the spur gear clockwise looking from the front of the truck. Whichever spins backwards needs to be flipped. ;)
jon perry 02-01-2012 05:44 AM
another very rookie question (i have to learn at some point) is the spur gear the one that is directly attached to the engine?
thank you vey much for your help
Snook Man 02-01-2012 11:07 AM
Clutch bell attaches to the engine, spur gear attaches to the transmission.
The screw heads the hold the diff housing together should be on the right side when looking at the front diff from the front of the truck and also on the right side when looking at the rear diff from the rear of the truck.
