Race Emaxx necessities. >
Old 01-12-2012, 07:16 AM
Trader Rating: 15 (94%+)
Default Race Emaxx necessities.
I picked up a brushed emaxx and looking to build a brushless emaxx for racing. I so far have bow tie 40 series wheels but is rather run truggy wheel setup. I need to know what is a MUST have to go fast with durability. Anyone have thoughts on a 2spd?
crash18 is offline
Old 01-12-2012, 07:36 AM
LaTuFu's Avatar
Trader Rating: 18 (100%+)
I don't know much about the MT classes, but I would imagine that you will need to do a BL conversion if you want to have any shot at competing.
Brushless motors generally have no need for a 2 speed setup, however.
LaTuFu is offline
Old 01-12-2012, 09:23 AM
Accordman's Avatar
Id do cvd's, upgrade shocks, smaller wheels then 40 series. shave weight anywhere i could.
Accordman is offline
Old 01-12-2012, 02:59 PM
+1 that running only 4 shocks will help, try and get heavy stuff mounted low too like the motor if you can pick up a low cog mount for it.
K1RC is offline
Old 01-12-2012, 06:29 PM
Here is parts with pricing
Suspension
Rpm arms. 23
Rpm rear true trac 30
Rpm ft knuckles 30
Flm shock towers 45
4 ue shocks 80
Steering
Traxxas 7075-t6 ft turnbuckles 15
Hitec servo 5955/7955 30-80
Driveline
traxxas ft/rr and center cvds 50 for ft/rr 30 for center
rrp diff gears 35-60
Traxxas 17mm hex 15-20
Tires
Truggy tires 40-80
I would also upgrade the bulkhead braces to aluminum so the bulkheads wont flex and break. Believe this really works. It makes them alot stronger.
ue-maxx is offline
Old 01-13-2012, 07:43 AM
Thanks fellas for the advice. I was going to run to 4 shocks. Didnt know how it act. Cvds are on the list. Ue emaxx thanks for the prices. Any one have diff and shock setups with the liquids? I have 17mm hubs to run truggy wheels got to find them or buy some any hub options? I have my savage ones but there M.I.A.
crash18 is offline
Old 01-15-2012, 09:46 PM
Diff and shock liquid setups. Any suggestens? Motor I'm goin to run the 2200kv from Castle.
crash18 is offline
Old 01-15-2012, 10:02 PM
Benefits if the RPM rear true track system besides what it says one the website. Does any one have info on what they thought of the true track system?
crash18 is offline
Old 01-15-2012, 10:09 PM
I've got the Tru-Track rear-end in my BL E-Maxx. Makes a world of difference, stability wise. Less stuff to adjust/move around/wear out.
Don't forget replacing the slipper, also. The stock slipper will puke it's guts out on a BL Setup. Get the Robinson Gen3 Slipper, it's bulletproof. I've got one sitting in a bag (65t) for when my Hot Racing Double-Up Slipper (6-Shoe) blows out.
WindDrake is offline
HTML code is On
