E revo motor mount issue >
Old 01-05-2012, 05:15 PM
Trader Rating: 24 (100%+)
Default E revo motor mount issue
hi guys i recently converted a brushless summit (mmp) to an e revo. But i am having an issue. whenever i give it full throttle the motor mount slips and the pinion and spur becomes un messed. its like no matter how much i tighten the mesh screw it slips. also as i tighten it the mounts wants to go towards the spur gear, so if i tighten too much my gear mesh is too tight. If i hold the car off the ground and give it full throttle it runs smooth, but soon as i hit the floor SLIP no more gear mesh. I hope you guys can help me out with this thanks.
chillymostly is offline
Old 01-05-2012, 06:17 PM
put some loctite on the screw i was having the same problem and that fixed it for me
salabarria is offline
Old 01-05-2012, 06:24 PM
thanks bro ill try that.
Old 01-05-2012, 06:27 PM
np man i hope it work
Old 01-06-2012, 05:36 AM
LaTuFu's Avatar
Trader Rating: 18 (100%+)
Is it the top screw or the bottom screw that is moving around?
If its the top screw, you may have stripped or worn the threads inside the motor mount.
If loctite doesn't cure the problem, you might want to get another motor mount.
LaTuFu is offline
Old 01-06-2012, 05:52 AM
thanks for the reply's guys. i figured it out. i had the pinion on backwards. lol. everything's a go now.
HTML code is On
