What Would Happen If . . . >
Old 01-02-2012, 08:05 AM
Red Sand's Avatar
Trader Rating: 19 (100%+)
Default What Would Happen If . . .
I would like to put 4 of the Pro-Line 1/5 Baja Bow-Tie rear tires (LINK) with Desperado wheels on my 1/8 buggy to create a super-bad monster buggy.
Is there any way I can get conversion hardware to go from 17mm to 23mm wheels?
It should look something like this when finished (image below).
I'm sure some gearing would need to be changed . . . if I can get this to work, it could be a cool project. I'm betting this has already been done before but I couldn't find any projects like this (1/8 using 1/5 wheels & tires).
Attached Thumbnails What Would Happen If . . .-po-ofna-1-8-scale-regular-vs-baja-5b-rear-wheels-tires-01.jpg
Red Sand is offline
Old 01-02-2012, 09:52 AM
Trader Rating: 24 (100%+)
You are going to create a self destructing GOOFBALL RC.
Every part on that thing will be subjected to way too much stress from the weight and size of the rims and tires. Good luck to you.
got_nitro is offline
Old 01-02-2012, 10:36 AM
Red Sand's Avatar
LOL!
I am sure you are correct! Thanks for your comment.
It was a fun idea to explore but, as you say, I'm sure it's impractical for several reasons.
As it turned out, the order I placed for my 1/8 machine was on back order so I cancelled it and will probably be getting a Slash 4x4 instead.
Thanks again,
RS
Red Sand is offline
Old 01-02-2012, 10:41 AM
Would've been cool either way. Not like I would do it but something I would look at and try it if I had the chance to hold the radio.
skipnay is offline
Old 01-03-2012, 01:44 AM
KK-racing's Avatar
First major problem you'll face is it cannot steer as the bigger wheel will rub against the chassis
KK-racing is offline
Old 01-04-2012, 09:51 PM
kstorm2k7's Avatar
proline makes the adapters and they space out the wheels away from the car
kstorm2k7 is offline
Old 01-05-2012, 12:24 AM
Ramos617's Avatar
I remember I tried out my rulux halfups with stretched badlands on my buggy
The body wouldn't fit so I ran it without a body but yea it handled terribly
It would go pretty fast though going down the street due to the larger diameter tires
Ramos617 is offline
Old 01-05-2012, 05:57 AM
roychan69's Avatar
Those that uses the wider wheel/tire combo will use the hub extender, it comes in 6 to 16mm extension hub, Mugen and OFNA make them.
It'll widen the truck and at the same time preventing the tires rubbing against the shock spring during turns.
You didn't know please keep your mouth shut.
roychan69 is offline
Old 01-05-2012, 06:13 AM
roychan69's Avatar
The link:
http://www.google.com.sg/url?sa=t&rc...B9G6Az9IBmxoIQ
Old 01-05-2012, 05:29 PM
KK-racing's Avatar
Sorry lah boss, 10 yrs ago when we tried tat nobody make the hub extender yet mah.
BTW, the thread starter oso didn't says he'll be using this hub extender mah. So u didn't read clearly & don't know the story can oso please keep ur Camel's mouth shut leh
It will be better you quickly go change ur monster stripped plastic spur gear & get ready for tmr bash than be a busybody asshole here !
Old 01-05-2012, 05:40 PM
roychan69's Avatar
Not busy body, but to educate you a little.
DoneED. It'll give your MBX-6 a real hard time tomorrow.
HTML code is On
