Help with T Maxx buid >
Old 01-18-2012, 05:35 AM
  #16
hotrod87's Avatar
Trader Rating: 252 (100%+)
Traxxas made a widemaxx kit for these it was all the parts and pieces to widen it out. Upper and lower aarms and the links. . This is the best place to start it was pretty cheap. Then do their forward only kit. And get a os18 and let her rip. It may not be the best racer but will get you some experience and you'll have some fun with it.
hotrod87 is offline
Old 01-18-2012, 05:39 AM
  #17
Suspended
Trader Rating: 41 (100%+)
^^ and shafts.
Cadimman is offline
Old 01-18-2012, 07:10 AM
  #18
cyclone x's Avatar
if your gunna do the os 18 make sure it is a tz with turbo head that motor is insane
cyclone x is offline
Old 01-18-2012, 07:42 AM
  #19
hotrod87's Avatar
The last one I did was with a sirio 18 . It was stupid fast until a rod broke with only a half a gallon through the engine . This was disapointing . Now I run OS.
hotrod87 is offline
Old 01-18-2012, 09:09 AM
  #20
will there is no wide maxx suspesion no more rpm just makes them all in one size which use to be the wide maxx but it now is stander i guess you could say. He will have to buy the turnbuckels for the new 3.3. The os 18 is now outdated for the maxx and they now sell a os .21 tm for it. If he buy the new 3.3 axles carrier he will need the steel drive shaft for sure casue the old plastic will not set right. It must have been awhile since some off you guy built your t maxx. I have one that i try to race when i can and it is updated. sometimes. The nice thing i like about the new 3.3 axle carrier is they have bump steer like the revo but that just depend on how much money he wants put in this thing. all the rpm stuff is around 40 dollars. Tower might still have parts that are a driect drop in for this .15 i dont know since i went the wide way.
imrob is offline
Old 01-19-2012, 07:24 AM
  #21
Default Tmaxx 4907 with sirio .23
I'm puttin a sirio .23 on my tmaxx (4907) model,the drivine is taken care of.but I don't know where to start with the transmission.where can I get these strong gears everyone's always talking about?
Secondly,if the ofna picco .26 max puts out the same power as this sirio,why is everyone saying there's no need to do a tranny upgrade.but with the sirio I will.....the only difference is the picco .26 max is bolt up ready to go with stock parts...but I don't know
dustineng is offline
Old 01-19-2012, 09:49 AM
  #22
robinson racing. or tower carry the parts have the steal gear. Gh hobby sell ally one but i just stay with the stock plastic on they hold up for me just fine. The plastic lasted about 3 years for me. The motor it might be cause one has a stronger bottom end then the other dont know myself.
imrob is offline
Old 01-19-2012, 11:02 AM
  #23
so,even with the monster sirio motor he tranny will hold up......and ive never heard anything about oiling those trannies,are you not supposed to oil them?
Old 01-19-2012, 11:20 AM
  #24
how the hell do you add a profile picture people!!!
Old 01-20-2012, 12:09 PM
  #25
IT depends on what gear's you have. If they are plastic gear's use white grease, if they are metal or the all i use black grease. My front diff i packed with some ford appoved wheel grease and i packe the full. The rear diff i used the same stuff but i only went about half in the rear. The profil pic has still got me bugged i have not got it to work yet. What i found out there is you have to have gimp some photo fixer thing. the pic can only be 80x80 pixels. and one guy said it has to be a grp code i think. im still trying to get this gimp to work. I did find out photo bucket dont work or at least not for me.
imrob is offline
Old 01-22-2012, 09:06 PM
  #26
So I bought a sirio .23 for my tmaxx,I bought a Motor mount on eBay that didn't work for my 3.3 tmaxx....I also bout an hoi.21-25 header and pipe,which also doesn't work....does anyone know anything about these sirios?
Old 01-23-2012, 08:55 AM
  #27
I think you need the ofan pico mount the one they sell for the pico point 26 that should work for ya. The pipe i have no clue the ths seem to be the best. Maybe a jp1 with a short header. I do reall like the ths one though.
imrob is offline
Old 01-25-2012, 10:30 AM
  #28
the picco .26 has the same block as the 3.3
thats why its a direct replacement
but even if.....noone can find one because people buy 'em before anyone even knows theyre there
Old 01-25-2012, 10:51 AM
  #29
No they have the same mounting holes for the chassie so the big block pico will fit that why they made. the pico is a big block. The 3.3 is small block.
imrob is offline
Old 01-25-2012, 10:56 AM
  #30
so even tho they state you can use your stock 3.3 motor mount,you cant?
maybe im missing something....im almost positive the 3.3 mount works on the .26 max
