Help WIth my SAVAGE >
Help WIth my SAVAGE
Help WIth my SAVAGE
Old 11-29-2011, 09:27 AM
Oscar16's Avatar
Default Help WIth my SAVAGE
I want to adapt a wing for my savage but i dont know what type of wing i can adapt if i can have opinions about that I will appreciate it
Oscar16 is offline
Old 11-29-2011, 09:45 AM
Used to be Blue groove had a Wing kit for the Savages, but they closed shop. Next I found a wing kit from New Erra, BUT the part is not in stock, and doesn't look like its going to be anymore.
Lastly I found Platinum-RC. Its a lil expensive, but SiCK.
http://www.platinumrcproducts.com/prc%20184.html
This will allow you to install a Stadium Truck style wing mount. They suggest using Hot Body’s C8152
http://www.toysonics.com/hot-bodies-...g-stadium.html
Others may work though. Im not too fond of the wing mount being so cheap on a CF mount, Id rather an Alloy or CF wing mount to use.
PLEASE post up other options found.
PS Platinum-RC also has some LCG Shock towers, & a wing mount to go with that too.
Rac3rX is offline
Old 11-29-2011, 11:18 AM
Suspended
Trader Rating: 41 (100%+)
I've seen guys use one for the TMAXX and make it fit from Techno RC.
Cadimman is offline
Old 11-29-2011, 07:35 PM
i made my own wind mount out of aluminum i got from a hardware store. if u are interested in making your own i can send u my template i used to make it. it has all the hole used to mount up using the differ cover screws and shock scres. you can put any wing on also as long as it can mont to a flat surface
wild248man is offline
HTML code is On
