Losi Muggy - will a 50t spur stick past the chassis?
Gearing it down and wanted to know if anyone has run the 50t spur and if it protrudes below the chassis?
ive went up to a 48, if all else fails drop a few teeth on the pinion or clutch bell, its easier and cheaper to do so! If not just mod and grind the chassis. I believe I had to grind away a little material from the chassis on the 48t...
Thanks, I shimmed the diff. carrier up and also filed chassis/servo tray and got it to fit.
