longer revo wheel base >
Old 09-15-2011, 02:18 PM
traxxmaker's Avatar
Default longer revo wheel base
want to widen the revo wheel base. A guy told me that they don,t make a widen kit for the front only the back is this ture?
traxxmaker is offline
Old 09-15-2011, 02:34 PM
he is probably talking about the arms in the rear that traxxas makes to give you about a half inch longer wheel base. but if you want a wider stance you have two options
longer wheel base
traxxas arms
and if you can find them qoncept hub carriers(1/2 longer wheel base)
wider stance
buy adapters (cheaper)
or
kershaw designs sells some extenders that you could use with the existing shafts but remember you are going to need also longer tie rods and push rods which he also sells.
hope this helps.
dasmurf93 is offline
Old 09-15-2011, 05:55 PM
traxxmaker's Avatar
longer wheel base
traxxas arms
wider stance
or
hope this helps.
thanks
Old 09-16-2011, 12:59 PM
LaTuFu's Avatar
Trader Rating: 18 (100%+)
iirc, the stock Summit arms are longer than the revo arms. The geode wheels are also 1/2" offset.
If you're looking for a relatively "stock" way of getting there...
LaTuFu is offline
HTML code is On
