Is one-way bearing gone? >
Old 09-11-2011, 03:40 PM
Default Is one-way bearing gone?
Everytime I turn over the rotostart the engine doesn't actually make the sound of fuel going through it. I just hear the starter spin. Does this mean the one-way bearing is gone? Or is it something else?
MT_MASTER is offline
Old 09-11-2011, 03:45 PM
Trader Rating: 24 (100%+)
You cant and no one else could know untill you pull it out and check it. Chances are it just needs to be cleaned and re-installed.
got_nitro is offline
Old 09-11-2011, 03:55 PM
Do I have to remove the engine to pull it out or can I just pull out the backplate?
Old 09-11-2011, 05:35 PM
Cant tell you, I don't know what you have.....99% of the time you have to pull the engine out, you want to pull the engine out just to make sure you put everything back on right.
Old 09-11-2011, 05:51 PM
Okay thanks
Old 09-13-2011, 08:07 AM
roychan69's Avatar
Okay thanks
Important: Use WD-40 to 'soak' you OWB, it'll last much much longer with some WD-40 in it than many said run it 'clean and dry'.
Don't worry, it'll not 'slip', in fact it'll 'grab' better.
roychan69 is offline
Old 09-13-2011, 04:52 PM
Okay thanks.
Old 09-13-2011, 06:08 PM
Okay thanks.
I found soaking it in nitro fuel then a few drips of synthetic 1.1 car oil works the best. I have done them many different ways too.
HTML code is On
