lst faster than revo possible? >
Old 09-01-2011, 01:54 PM
Default lst faster than revo possible?
I have a lst with a .28 lrp engine with 70/63 spur and 18/25 clutch bell and my friends revo is faster. Is it even possible for my lst to be faster than a revo?
losifan94 is offline
Old 09-01-2011, 02:05 PM
For 30 bucks you can get the tranny output gears from the XXL and a 19/26 clutch bell, and you'll have him...
Herrsavage is offline
Old 09-01-2011, 03:41 PM
I have him off the line but then he passes me. Will the 16/29t clutch bell make it faster also?
Old 09-01-2011, 05:18 PM
yup, if you have him off the line you can afford to go up a tooth, and you will get a little more speed.
troy8481 is offline
Old 09-01-2011, 05:33 PM
Cummins Driver's Avatar
Trader Rating: 19 (100%+)
Its easy. Just jump him off the line and then run him over whenever he gets beside you. Problem solved. lol
On a serious note... How much is he beating you by? How much more top speed do you think he has? Doing what HerrSavage reccomended should help your top end a decent bit.
Cummins Driver is offline
Old 09-01-2011, 07:57 PM
He's beating me now by about 5 m.p.h. I have the stock gearing and everything that it came with. I think the extra tooth should give me an extra 2 m.p.h and the gearing another 1-2 m.p.h . The old engine that it came with didnt have a chance but the lrp has almost a full horse more than the revo 3.3
Old 09-01-2011, 08:03 PM
Shem1's Avatar
Or for even faster use this combo:
F/R Bevel Gears 28/17t (LOSB 3120)
Losi High-Speed Clutch Bell 19/26t (LOSB 3342)
Shouldn't have a problem smokin a Revo with that setup.
Shem1 is offline
Old 09-03-2011, 10:52 AM
ntrain42's Avatar
Trader Rating: 33 (100%+)
Tons of ways to gain speed or acceleration. Losi makes different pinions, spurs, and 3 sets of transmission gears. Even a FOC will make significant improvements and reduce rotating mass.
ntrain42 is offline
HTML code is On
