-   Monster Trucks (https://www.rctech.net/forum/monster-trucks-46/)
-   -   Revo dif problems (https://www.rctech.net/forum/monster-trucks/542556-revo-dif-problems.html)
REVORACER24 08-16-2011 11:44 PM
Revo dif problems
Hey guys i accidently fully unscrewed the screw that changes the gears faster or slower in my revo. Just wondering how i can get it back to factory settings. And also when i took the dif casing apart to get the screw i found a loose small spring and what looks to be a ball bearing anybody know? Thanks and also whats the best engine i cam get for my revo
alexrckid 08-17-2011 04:22 AM
sounds like you're talking about the shift point screw in the tranny.....there's no such screw in either of the diffs......yes..??...no..??...........
J.Whiting 08-17-2011 05:30 AM
please use the correct forums when posting on rctech.. this is a monster truck issue.. please use the monster truck forum.. i moved your post there.. thank you..
BashemSmashem 08-17-2011 07:45 AM
Yeah , I think you meant the transmission . You will need to take it out and dis assemble the trans case and put the spring/ball/set screw back into the 2 speed hub that sits inside the 2nd speed gear . Traxxas has a really good exploded view you can use too see how it goes together .
REVORACER24 08-17-2011 08:03 AM
Alright thanks everybody for the helP really appreciate it amd to j whiting il make sure of it next time thanks
REVORACER24 08-17-2011 08:08 AM
Hey another thing im looking at the picco .26 max and the os .21 tm for revo not sure of which one is better
REVORACER24 08-17-2011 08:10 AM
Its allright i got it fixed but thanks for the fast reply
NDHotbodies 08-17-2011 06:19 PM
go with the .21 tm I put them in my Platnums this season and they have been working great. tried the big block thing for 2 years and that .21 is all the engine the revo needs.. getting the same lap times with my MT as my truggy.
REVORACER24 08-17-2011 08:28 PM
Hey are you talking about the picco big block? Any ways thanks sO much!!
NDHotbodies 08-17-2011 08:50 PM
no I ran mostly GRP .21, great engines, just seem to have issues with the big block set hardware,{loose screws, weak mounts just simple stuff just happening at the wrong times...
REVORACER24 08-17-2011 09:18 PM
Oh alright il check em out are you recomending them?
REVORACER24 08-17-2011 09:23 PM
Would you recommend the grp .21 or the os .21tm for revo
REVORACER24 08-17-2011 09:24 PM
And umm did u purchase the traxxas big block conversion kit or do tou have a revo
NDHotbodies 08-18-2011 08:54 PM
yes I used the traxxas BB kit, worked great but kind of like putting a v-8 in a vega.. real tight.. the o.s. 21 tm fits right in with no mods needed. strong engines..
