Ever had this problem???
My savage 4.6 keeps losing the slipper adjusting nut and the clutchbelk holder screw. I've used loctite on them but it doesn't seem to work. When I put the nut and screw back in they just back right out when running it. I have to keep checking to make sure they are even there about every two minutes or they'll fall completely out. Thanks guys.
You need a new nylock nut for the slipper and you may need bearings and/or shims for your clutch bell.
The nylon nut was brand new since I lost the old one. Brand new in package and it still does it
The slipper slips and the nylon burns out.
On the CB bolt - make sure you give the loctite a chance to dry, I usually leave it overnight if I have the time.
The slipper nut, I have no clue... smoked many slipper pads on plastic and steel spurs and never replaced the nut or had any loosening issues.. I set my slipper tight until there is no gap in the spring and snug (don't overtighten), then back off maybe 1/8 turn. |
| All times are GMT -7. It is currently 02:52 AM. |
