Ultimate LST XXL monster build!
#301
i had a savage once but it was waaay overweight and a bitch to work on..so complicated! and you gotta run 2 lipos which i hate!!
losi's are the easiest to work on , wether its a little 1/10 scale, 1/8 or 1/5 scale its all the same layout and thats what works and is simple!
#304
ttt
#305
thumbs up
#307
[QUOTE=twissted;13974643]You should check out my Losi Aftershock build with a Carbon Chassis that uses a Traxxas Summit Trans with Micro servo to shift when needed!
what body did you use and what scale? tnx
#308
Any tips on getting more power out of the lrp zr.30x? Maybe a different pipe? I contacted extreme mods for one of their pipes but i didn't get an answer. Anything else?
#309
Pipe, nitro % and using the SMALLEST carb insert...........use the smallest carb insert with a longer tuned pipe(torque), is the best combo for the .30X.
