Buying a Losi LST XXL - Thoughts/Tips/Tricks
#61
Regardless the stock metal pads I have never found any issues with being grabby or incosistent(though I do use a 7955 servo or any binding even. I do use the fiber pads on my race XXL, but again using a high torque Hitec 7955 servo I have never noticed any performance improvements over the stock metal pads. If anything, one downside to the fiber pads is they wear out pretty quick on my rig.
So metal pads could be considered an upgrade though because they do last alot longer, that is one thing I definetly have noticed.
#65
I must have gotten me a real good xxl then lol. My truck when rolling on the breaks stops real nice and quick. Now like I said if I just slam on the breaks its a whole different story. Front flip city lol.
Me myself I'm fine with my stock breaks and will be keeping them that way. I don't think the truck needs more break lol..
#66
Question for you guys. Do you run one servo or two? If one did you modify the steering linkage at all, or just leave it and just run the single servo?
#68
I got mine used servoless. I added one 180oz servo and it seems to be doing ok so far. might add a second, but i'll have to buy all the hardware and a y adapter to run two servos.
#69
Well to do a "proper" single servo mod you should be using a seriously solid single servo, thus being able to eliminate using a servo saver. The Hitec robot servos are steel/titanium geared servos that are brutally tough. Take a short titanium rod and screw on captured ball ends, then attach to a good solid servo horn, and the other end to the steering crank. Now you can rip the wheels in any driving condition imaginable. It's a highly desirable mod. If you stick with the dual servo's I recommend at the very least beefing up the stock servo savers with a couple of extra springs or ditching the stock savers and picking up some of the Associated savers which are far less forgiving and will give you more control over your steering.
#70
And why people mention robotic servos I have no clue. Hitecs robotic servos are just regeared HV premium servos that have slower transit speeds for a couple extra ounces of torque that are honestly not needed.
#72
They have more steering throw,but slower transit speed times, and if your buggy/MT is set up correctly with the correct servo horn it will never use more than 60 total degrees. Most steering setups are designed by nature to use only 55-60 degrees turn. No point in having extra throw when you can't utilize it in the application. If your buggy is a Losi 8ight or RC8T, they both use just under 60 degrees maximum throw when set up with the right horn. Thats my take.
#73
Cool, thanks for the info guys. Do you use a splitter to run the two servos?
Also which associated servo saver do i need?
I got my truck used, and it was setup with a single servo, no servo saver, and its missing some of this stuff which is why i am asking.
#74
Remind me real quick: Which truck do u have? LST?
#75
