-   Monster Trucks (https://www.rctech.net/forum/monster-trucks-46/)
-   -   Will it work? (https://www.rctech.net/forum/monster-trucks/487984-will-work.html)
mike22 03-02-2011 12:42 PM
Will it work?
I'm thinking of using my emaxx esc the blue 16.8v to my crawler with dual motor but I don't want to use two battery, will wiring the two red wire and two black wire so it shares just one battery work? Tnx
BlackwoodXXL 03-02-2011 01:13 PM
mike22, heres were I get my battery wiring info
http://www.scriptasylum.com/rc_speed/index.html
In the Electrical/system section it shows The EVX2 wiring diagram with or without fans, hope this helps.
RCaddict0 03-03-2011 02:25 AM
That ESC is used in the Summit with a single 775 motor wired the way you want to use it. So, as long as your motor can handle the voltage you plan on using it will be fine
Jstall7543 03-03-2011 03:22 AM
Have Neo consult the oracle! Hehee!
Jstall7543 03-03-2011 03:26 AM
Morpheous said that she said: Outlook not so good! I wonder what that means? Hmmm :ha:
mike22 03-12-2011 08:22 PM
It works :)
