worth it or not? >
worth it or not?
worth it or not?
Old 02-10-2011, 06:20 AM
ckblood05's Avatar
Trader Rating: 15 (100%+)
Default worth it or not?
i know my t-maxx has that limited slip rear. are these worth it to install? will this make both rear wheels turn at the same time? and can you put these in the front and rear?
http://cgi.ebay.com/Traxxas-Differen...item5adb7be200
ckblood05 is offline
Old 02-10-2011, 06:29 AM
R/C Tech Elite Member
RevoRacer50's Avatar
Trader Rating: 41 (100%+)
yes you can put them int he front and rear but its going to limit the turning radius a lot more then what you want. what are you plans for the truck? and if you do instal them upgrade the ring and pinion as well. I have a hill climb revo that i used them in front and read.
RevoRacer50 is offline
Old 02-10-2011, 06:49 AM
ckblood05's Avatar
i just do bashing. i will be driveing on a dirt track a lot. if there only good for going straight, then i cant use them.
Old 02-10-2011, 09:46 AM
440swinger-kid's Avatar
Trader Rating: 50 (96%+)
You wont see a improvement on your 4x4 r/c....... like he said only for pulling or climbing would you use that, But are awesome for 2wd r/c IMO but 4x4 r/c keep the open diff
440swinger-kid is offline
Old 02-10-2011, 10:15 AM
ckblood05's Avatar
ok, i kinda figured so. i'll stick with the diffs i got.
Old 02-10-2011, 02:11 PM
Yeah spools kinda suck. They are good for the above mentioned things plus awesome donuts, but stuff will break.
trxnut454 is offline
Old 02-10-2011, 04:48 PM
yes it will break man things. when i put in my spools i also put in cvd new diffs and bulks and robinson trans kit and forward only just so everything will hold up to the os speed and 1/5th scale wheels but all i do is hill climb so i left the rear drive shaft stock so it would be the only weak point so i could break something that was cheap.
HTML code is On
