-   Monster Trucks (https://www.rctech.net/forum/monster-trucks-46/)
-   -   hsn problem! please help (https://www.rctech.net/forum/monster-trucks/465391-hsn-problem-please-help.html)
ckblood05 12-28-2010 06:02 AM
ok, i loosened up the nut on the bottom of the hsn on my t maxx to move the nipple the fuel line goes on. after i got it where i wanted, i went to tighten the hsn nut and it just turns. plus i can wiggle the whole hsn valve in the carb where it screws in. the threads on the hsn are fine. but i noticed theres no threads where the hsn screws into the carb. i tried to put some teflon tape on, and still loose. i can actually wiggle and pull out the whole valve when its in all the way. i tried to start the engine and fuel sprayed out around the bottom of the hsn. how do i tighten up the hsn valve in the carb? do they use some kind of sealent or silicone? im going to my lhs later today to use my gift card, so can some one please give me some info on this before i go? that way if i need to buy anything, i can get it at my lhs. thanks.
got_nitro 12-28-2010 06:08 AM
Your carb body is stripped out, good job:lol::p;) Thay are plastic and do that often very easy.
Your better off looking on flea bay then buying a new one at full retail at the LHS.
ckblood05 12-28-2010 06:16 AM
ohhh man! yea i noticed when i took out the hsn valve, there was plastic like pieces on the threads. i got some ultra black rtv sealent. can i put that around the hsn like the threads?
got_nitro 12-28-2010 06:17 AM
You can try it, Im sure it would/might work for a bit if not longer..
ckblood05 12-28-2010 06:19 AM
Originally Posted by got_nitro (Post 8399998)
You can try it, Im sure it would work.
ok, i'll try. i mean if i am going to buy a new one, even if it dont work, im not out anything. theres some on ebay brand new for around $26 shipped. but theres also some at only $6, $13 auction. so ill try the rtv let it cure for a few hours and try it.
got_nitro 12-28-2010 06:27 AM
Yep, thats what I would do. Got nothing to lose now.:cool:
ckblood05 12-28-2010 06:51 AM
ok, i got it on. i'll let it cure for 24 hours. i'll give it a try tomorrow around 11-12. if it leaks, i'll just bid on one of them carbs on the bay.
trxnut454 12-28-2010 07:31 AM
Why bother! You're just gonna get either plastic bits or rtv into your engine, ruining what would've been a good glow plug. Even if it works it won't hold when you go out and run it. You need a carb body or a complete carb.
ckblood05 12-28-2010 08:31 AM
im bidding on a whole new carb w/ hsn. i'll try it still just to see if it works. i made sure i didnt get any rtv on the inside.
trxnut454 12-28-2010 01:24 PM
Well, good luck.
ckblood05 12-29-2010 03:08 PM
well, i took off the carb. i needed to remove the engine anyways because the blue aluminum engine mount i ordered will be coming. im bidding on a new carb now.
