should i put these into production?( savage flux/xl ) >
Old 12-25-2010, 08:40 PM
Default should i put these into production?( savage flux/xl )
as i was breaking the outer axles at an alarming rate, i decided to prototype a set of braces to keep the axles from splitting apart. i have never heard of this happening on the older types but some people have had the xl and flux ones split apart.
the braces only fit the trucks using shd axles like flux and xl
this is what i'm talking about. the third one is a new unused for comparison
and here is a picture of one with the prototype installed. (the prototype has overly thick walls 3mm but production one will have 2mm)
here is a 3d pic of the prototype.
and a 3d pic of the production one. the difference is that, the wall thickness on the round part is 1mm thinner
please give me your thoughts on the matter, if i should start making them.
the prototypes have held my axles intact since i put them on so i have no worries about selling them as an upgrade parts.
edit: all the ones that broke, were at the front wheels. i think it only happens during extreme force while the axle is at an angle to the outer axle. the other cups do not see as much angle as the outer front ones. so each kit could be just two braces, but you could put them on all the cups, 8 in total.
mrsnuggles is offline
Old 12-25-2010, 11:25 PM
rcjoe99's Avatar
i dont know how much they cost to make each but i would kinda start small try to sell them on ebay or something then if they are a good seller then go big with them
rcjoe99 is offline
Old 12-26-2010, 04:03 AM
LiqrSicc's Avatar
Trader Rating: 10 (92%+)
I haven't had problems with my axles yet but that looks like a good simple fix. How would you keep the brace from sliding around though?
LiqrSicc is offline
Old 12-26-2010, 06:08 AM
there are many ways to keep them from sliding.
electric tape behind them.
epoxy (flexible type)
silicone sealant.
and my personal favorite soudal carbond 940fc (this stuff fixes everything and is what i use)
the stuff only has to prevent them from sliding and the material must be flexible.
i noticed that ca glue only cracks and with time it will wear off.
Old 12-26-2010, 10:15 AM
helivaguy's Avatar
Trader Rating: 42 (100%+)
oops sorry.
helivaguy is offline
Old 12-26-2010, 10:17 AM
helivaguy's Avatar
thats a very good idea..you can shrinkwrap them on.
also try a pressed-on steel tube version.
Old 12-26-2010, 11:30 AM
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
if you can make a sleeve the entire length that might make more sense. also, make sure you don't need to have some extra room free for the drive pin to clear what your adding on.
hanulec is offline
hanulec's Avatar
btw - what cad program did you use to make your drawings in??
hanulec is offline
Old 12-26-2010, 01:11 PM
I have been making these for years. Make from aluminium tube, use on outdrives and stub axles, have not had one break since i have been using them
rcspeedfreak is offline
Old 12-26-2010, 05:11 PM
making it so it goes the entire length only adds extra weight and makes them expensive to make, the pins are not long enough to touch the braces.
the fit is extremely accurate so there is no play at all.
they are stainless steel, so no worries about them not being up to the task.
HTML code is On
