Summit? revo compatibility >
Old 12-25-2010, 01:37 PM
Default Summit? revo compatibility
I was wondering how compatible the e-revo and the summit really are? What, if its possible, would I have to do to put summit front and rear diffs in my revo? I thought it would be cool if I could lock it up in the winter for better traction just by clicking a button. We all know how fun it is to get into the diffs on a revo and I hate having to put in a hole evening every time I want to change something. I'm guessing I would need another servo to operate the diffs but I don't own a summit so its just conjecture at this point. Anyway any help would be great. I have a dx3s and a sr3000 which should be able to handle the extra servo/ servos.
red dog is offline
Old 01-07-2011, 05:12 AM
Jrz13's Avatar
there the same truck, the only diff is the diffs the 2 speed and the body. the servo, the t loc diffs, and linkage are what youll need, honestly im not sure where it all goes, check out your lhs or local track to get a better look. then let me know, id like this mod too.
Jrz13 is offline
Old 01-07-2011, 05:31 AM
R/C Tech Elite Member
nexxus's Avatar
Trader Rating: 315 (100%+)
Just finished a conversion of an E-Revo to Summit
you need:
4 Chan Radio
Body Shell
Body Posts
Rear Arms (Extended Wheel Base)
Driveshafts (E-Revo ones are diff)
Front/Rear Diff AND Bulkheads
2 Speed conversion for transmisison
Single Motor Mount
Wheels/Tyres
LED's
Linkage Set
3 * Micro Servos
Shock Oil and Springs are diff
Chassis also needs some dremel work to clear diff linkages
nexxus is offline
HTML code is On
