t-maxx radio issues... >
Old 10-26-2010, 09:30 AM
Default t-maxx radio issues...
I've got a new model t-maxx and having some weird issues with it.
Everything was working fine to begin with, but then i started having range issues; I was limited to about 20-25 yards before it would get out of range. Over the course of the next two days, the range got shorter and if I hold down the throttle at 100%, the throttle servo would go to full throttle and then start backing off and going back to full throttle; back and forth.
Any ideas?
mr.s4ndm4n is offline
Old 10-26-2010, 10:48 AM
Trader Rating: 21 (100%+)
Have you looked at the antenna and made sure there's no cuts or nicks on it?
If teh radio you're using has crystals, re-seat them both. You have checked and made sure rcvr an tx batts are good?
Duster_360 is offline
Old 10-26-2010, 07:49 PM
I'm going to take a look at the antenna as soon as i get back.
As far as the remote goes, its a new style Traxxas TQ 2.4Ghz high output link radio system. So, i dont think it has 'crystals' in it, but i'm not sure?
All the batteries have been replaced/charged and still have the issue.
Old 10-26-2010, 08:07 PM
No, there's no crystals, my bad, I see now you said new....
See pg 10 - bottom corner, make sure you antenna wire hasn't slipped in the antenna tube or the end part gotten bent or crimped.
You might try rebinding the rcvr also pg 10.
HTML code is On
