Cant Steer
Old 10-14-2010, 08:22 AM
  #16
Bighomedog11's Avatar
The one i had in there was a
Ultra Torque
Hitec
HS-645 MG
And i put a
Traxxas 2055 in there
Which one is better?
Bighomedog11 is offline
Old 10-14-2010, 10:04 AM
  #17
Trader Rating: 21 (100%+)
The Hitec 645 is better - here's its specs -
SPECS: Speed: 0.20 sec/60 at 6.0V
Torque: 133.31 oz-in at 6.0V (9.6 kg-cm)
Length: 1.59" (40.6mm)
Width: 0.77" (19.8mm)
Height: 1.48" (37.8mm)
Weight: 2.11oz (60g)
These are the specs on the 2055 -
SPECS: Length: 1.6" (40.5mm)
Width: .8" (20.5mm)
Height: 1.43" (36mm)
Torq: 80 oz/in
Weight: 1.58oz (45g)
You used to need to upgrade the servo saver when you swapped to a MG servo to get all the benefit from it you could (also to better protect the gears too). The stock saver was too 'mushy' with a 645.
Duster_360 is offline
Old 10-14-2010, 10:26 AM
  #18
SloRacer1080's Avatar
Trader Rating: 15 (100%+)
Unless he has a 3.3 maxx that has the servo saver built into the bellcrank If not the heavy duty Kimbrough one is a popular choice.
But yea put that Hitec back in there. Thats exactly whats in my truck. Works great
SloRacer1080 is offline
Old 10-14-2010, 02:59 PM
  #19
Alright i will put it back in there.. I was reading that the 2055 will be good for the brake and throttle..
But i had the 2.5 tmaxx and i put a 3.3 in it But all the components are 2.5 but the motor.
Old 10-14-2010, 06:34 PM
  #20
This is the servo saver I switch to when I ran a 645 in my 2.5 -
http://www.amainhobbies.com/product_...Hitec-Servos-1
It does a much better job than teh stock one.
Old 10-14-2010, 09:06 PM
  #21
roychan69's Avatar
Hitec servos, high torque, cheap and reasonably good.
http://www.google.com.sg/url?sa=t&so...iVgPLAPiPuH6gg
roychan69 is offline
Old 10-14-2010, 09:30 PM
  #22
I have one of those on my steering servo.. I did not realized i had that until i looked at the link. I got this truck used so the guy already did some stuff to the truck
But i put the 2055 servo as my throttle/brake servo because i heard a good servo for that spot.
HTML code is On
