flux xl wih baja tires? >
Old 08-16-2010, 05:54 PM
symmetricon's Avatar
Trader Rating: 27 (100%+)
Default flux xl wih baja tires?
I am wondering if the 24mm adapters from hpi on a savage is a good idea. I am interested if anyone is rolling with baja treads in their flux? Does it overheat the motor and speedcontrol? Does it improve handling much? Or do "you" have any thoughts or concerns?
symmetricon is offline
Old 08-16-2010, 05:58 PM
Trader Rating: 51 (96%+)
It's a horrible idea. Have you ever seen a Baja tire in person or even held one? They are SO HEAVY. You will add at least 4 lbs to the weight of the truck switching to them. It WILL over heat your motor, it WILL end up damaging it.
CaseyDDR is offline
Old 08-16-2010, 07:15 PM
My interest is actualy having a hex hub instead of a wheel nut... is there any problems running the 17mm hex hub adapter on a flux xl-with the xl axles?
Old 08-16-2010, 07:26 PM
Super Moderator
nexxus's Avatar
Trader Rating: 307 (100%+)
Standard 17mm Hex adapters won't fit as the pin won't line up with the axle. The HPI 17mm hex adapter kit with CVD's do fit but the shafts are thinner and they are far too small for the diff so you have a lot of play there.
Fact is on the Savage Flux, you are stuck with HPI's 17mm set up, nothing else fits. I suggest investing in an 8mm ring spanner to tighten the wheel nuts up that extra bit.
nexxus is offline
Old 08-16-2010, 08:01 PM
Trader Rating: 43 (100%+)
i have a set 4 rears of 24mm hexes if you want to tray and use them 2 are new 2 are slightly used.
pm me if you are interested.
i seen a savage flux running 5t tires and he had no issues at all, ultimte hobbies and pi sponsered a event at the last 3 monster jams out here in so-cal.
navyeoseabee is offline
Old 08-16-2010, 08:15 PM
I did find his mod.
http://www.savage-central.com/Evo-Fo...t_-_84355.html
Any thoughts? It looks like it has been a while since anyone posted on its succes.
HTML code is On
