Clutch assembly problems for E-Revo 1/8th >
Old 08-11-2010, 09:16 AM
Default Clutch assembly problems for E-Revo 1/8th
Hello all,
My entire clutch assemble got destroyed when it was being powered by two 3s lipo's. Damaged parts are 3 Friction Pads, Traxxas Slipper Pressure Plate, Spur Gear.
What can I do from preventing damage to my new installed clutch assembly?
joydude630 is offline
Old 08-11-2010, 01:18 PM
TCRacer101's Avatar
Trader Rating: 16 (100%+)
If you're looking for upgrades, Robinson Racing has a heavy duty slipper assembly. http://www.robinsonracing.com/catalog/e-revo.html
Only thing is, they only have 60T and 65T spurs....
TCRacer101 is offline
Old 08-11-2010, 02:55 PM
Keep it tighter. What probably happened is it was a little loose burned pads heat softened the spur gear and bam. Your day is over.
MalicousIntent is offline
Old 08-11-2010, 02:58 PM
Trader Rating: 57 (97%+)
tighten it all the way down then back off 1/4th turn.
CaseyDDR is offline
Old 08-11-2010, 02:59 PM
Trader Rating: 21 (100%+)
+1 - once they get even a touch loose running 6S, its gone. Replace everything, even the nut and cut the adjustment in at least half. Try again - and oh yes, buy plenty of spares!
Duster_360 is offline
Old 08-12-2010, 07:41 AM
Thanks guys for the replies. I will tighten it and give it a go.
Old 08-14-2010, 06:07 PM
this seems to be a pretty good setup
Gho5tRevo is offline
HTML code is On
