Out of control Emaxx! > Out of control Emaxx!
Old 08-01-2010, 08:46 AM
Default Out of control Emaxx!
I hooked my Emaxx 3905 up with a MMM and 2200kv motor. For now I'm just running NiMH Batteries. And they are kinda old. One set is 5000 mah and one set is 3800 mah. Sometimes it will accelerate by its self, full throttle. I have no control over it. Could it be my tx or rx causing this? It did it with new batteries in the tx and from a very short distance from me. I have also run dual 700 HO motors in this same truck and this never happened. Let me know what you think.
thanks
Emaxxmonster is offline
Old 08-01-2010, 09:00 AM
check your wire and conection to the reciever for cuts.
did you do the esc learn- full throtle , brake , neutral ?
rc everywhere is offline
Old 08-01-2010, 11:55 AM
I did do the full, neutral, reverse throttle programming. I'll try it again and post the results.
Old 08-01-2010, 06:46 PM
Well I reprogrammed the esc learn forward,brake, neutral. It seems to have worked. I'll be back on here if it starts happening again.
Thank for your help!
HTML code is On
