e revo with lipo batteries >
Old 07-25-2010, 01:17 PM
Default e revo with lipo batteries
I just bought a e revo and got two 2s lipo batteries and I was wondering if I need a low voltage detection or can I just time the runs
salabarria is offline
Old 07-25-2010, 01:28 PM
you should get a cutoff. all it takes is one time draining the batteries too low to ruin them.
scarletboa is offline
Old 07-25-2010, 01:33 PM
Xmod_Racer's Avatar
Your runtimes will vary depending on how hard you drive and what you do etc., so timing the runs can never be accurate. Just get a low voltage cutoff and play it safe. It never hurts to be too cautious with lipos
Xmod_Racer is offline
Old 07-25-2010, 01:38 PM
Can someone link me a good low voltage detector for the e revo
Old 07-25-2010, 01:47 PM
Trader Rating: 21 (100%+)
There is nothing wrong with timing your run - run a short one, 5 to 7 or 8 min and then stop. Recharge the lipos and see what went back in them. Calculate a mah/min and based on running to 80% of your lipo capacity, calc a run time based on that figure (not the total capacity). Now subtract a safety margin to keep your lipos safe. You have to pay attention to the time though, one time running longer than your capacity, you may damage the lipos.
Novak makes an add on fail safe called the Smart Stop. You'll need the 4S one. It wires into the pacs - neg to one lipo, pos to the other lipo. There is another one made by FMA, but its not used in surface and would be a prob to wire to dual lipos.
http://www3.towerhobbies.com/cgi-bin...?&I=LXPGN1&P=7
Duster_360 is offline
Old 07-25-2010, 04:16 PM
Trader Rating: 51 (96%+)
Just run them till you see it losing a bit of power then stop. It's what I do and I never go below 3.3v per cel doing this w/o a cut off.
CaseyDDR is offline
HTML code is On
