Going back to Flux. Fill me in on Lipo & chargers
#16
i fixed the link in my first post.
#17
Oh my 6000maH 28c SMC's performed well, It was the fact that I learned the hard way and from hearing from SMC themselves that
1. Being a "racer" battery, they do no like to have a full charge on them longer then 12 hours. Otherwise, the chemical makeup of the battery falls apart and it starts to puff *fate of my 2nd pair*
2. Faulty and poor chemical composition has resulted in SMC lipos that failed under moderate loads, warm temperatures and other variables *fate of my 1st pair*
3. Due to lack of flexiblity from #1 in not being able to to just charge my Lipos and let them sit for days and use them when I feel like it, I can't justify their costs.
#18
R/C Tech Elite Member
I'm just using a couple of el cheapo Venom 4000mah 20C Lipos in my Summit, charged on a Turnigy Accucel 6, I keep them both charged and usually use them within the week without issues.
Surprised you got banned on HBF, I have been on that forum for years and haven't had anyone say boo, and I'm not exactly the most user friendly person out there.
#19
Its one thing to be somewhat unfriendly. Its another to call Rob out on his moderating ways and telling him to go screw himself
Last edited by Freezebyte; 07-28-2010 at 12:34 PM. Reason: removed profanity , issued infraction
#20
www.progressiverc.com
You want to be a charging god? Check Dave's stuff out. You can buy chargers and power supply's that take care of business. Currently I run the Icharger 208B and the P350 power supply. Get the Parallel squid lines and balance leads from Dave and you can charge 6 2S Lipos in like an hour and 20 minutes. With some of those new setups he has at 30 amps, 6 2S lipos would be done in one hour. You convince the charger that you hooked up a 30,000mAh battery to it and you're good. I have been doing it for a while now and they are always balanced. It's insane.
Check it out, call him up, real nice knowledgeable guy.
Speaking of those new Hobbyking packs. I have some of the 6000mAh 25-50 2S packs coming for my Flux. My buddy got a 3300 45-90c 3S for his Rustler. No joke, he slams that pack at 20 amps with the iCharger 208b and it's done in 11 minutes. The cells stay balanced from 3.2 to 4 volts, bottom to top. I sat there and watched it because he scared me with his crazy talk. It didn't even warm up. It runs for 25 minutes doing speed runs in a parking lot. That stuff is legit.
#21
You remember a bit of an argument you got into with a gentelman named SureToCrash, at RCU around this time last year? It was about some SMC Lightning Volts 3s 3400 18c packs.. Anyways, I bought his flux, and ran those lipos myself both in my flux, and my erevo, and to this day they are still pretty good packs, tho runtime is a bit limited, being only 3400s
#22
I just thought youd like to know..
Think about it, if we were all physically in a big ball room at a party. The party is called "The RCTech.net party." Would you go running around talking bad about other people at the party or tell them to F off? You would be all loud, bringing a spectacle upon yourself? I hope you would not. You are not going to make friends and then you would probably be asked to leave. If you don't care about making friends, than that's your prerogative. If you don't care because it's "not real" because it's the internet than that's stupid. This world we live in, as big as it seems, is not that big, especially the RC community. You should minimize bridge burning in life.
#23
Understandable, i'll let it go. I finally sold the 5T today, Wooo! Now "Frostbyte II" project has begun!
#25
Hmm ok, im also torn with buying two of these instead of the Dynamite Ultra so I can do 2 lipo's at once. Input? Are they quality chargers? The price is freaking awesome, even for two with shipping!
http://www.hobbypartz.com/thac6smbachw.html
I had a Flightpower Triton 2EQ with my first flux. Nice charger, but overpriced.
I also can't find out what the maximum battery mah size this charger can handle, anyone know?
#26
that charger will do exactly what you want/need it to do. i have a similar charger that uses the same programming and it has worked very well or me for almost 2 years now. the only difference is mine is a DC only charger and i use an external PSU.
there is no limit to mah you can charge on it. i charged a 50ah car battery with mine.
you could charge a 2s pack at the full 5a or a 3s pack at about 4.4a due to the 50w limit.
long story short, you will love those chargers and they are perfect for what you want to do.
#27
Ok, I just remember seeing some chargers with like a 9000mAh battery limit or something like that. I do realize that beyond 5000mAh it will take a bit extra time to charge but I could still charge two Lipos at once if I got two of them vs single 8amp passport ultra. I think I still come out charge time ahead if my math is correct
For a theoretical example:
Four 2s 7000mAh Lipos w/single Passport Ultra @ 7amps = 1 per Lipo = over 4 hours to charge
Four 2s 7000mAh Lipos w/ two AC6 @ 5amps = approx 1.5 per set = approx 3 hours to charge
If I factor in doing a 3S 5000mAh Lipo or above i'm looking at at least 1.5 hours per Lipo on each AC6 due to wattage limit.
Hmmmmm......
Hmmmmm......
#28
So wait, how does the charger known when to stop charging a Lipo after a certain capacity point if it doesn't allow you enter the batteries max mAh capacity? I had to do that with my Triton 2 EQ but I don't see where you enter that on this charger.
#30
I got my flux in the mail today.
I've heard some people complain about the HPI fresh-from-the-factory smell, but personally I love it. It smells how I think a 50+mph rc truck should smell.
Unfortunately I can't run it yet because UPS is playing games with my battery shipment. It's tracking status has been stuck at the same thing for a few days now: HODGKINS, IL, US 07/26/2010 8:00 A.M. ADVERSE WEATHER CONDITIONS.
Lame.
Lame.
