Clutchbell steel or metal ??
I would like to know what would be better for my 3.3 t maxx... a clutch bell that come with it or a steel clutch bell with a metal spur gear ??
well i don't really have a problem with with the CB, its just i bout a metal spur gear and i would like to know was it worth the money to get one and i need to get a new spur gear. so which CB would be better? oh i have an extra spur so i can switch it back .. But which steel CB is better vantage or harden ??
If you not having probs with the stock CB/spur, seems like its a waste to change to a hardened CB just to run a steel spur. My 2 Tmaxxes never had probs with the stock CB/spur. Plenty of other stuff to spend the money on.
I had to charge to steel spur on my Emaxx since I kept melting spur gears, otherwise I wouldn't have charged that either.
the reason you were melting spur gears on your e-maxx was most likely because of either too tight of a mesh or more likely, your slipper was too loose and got really hot.
