Tamiya TNX
Old 01-21-2005, 05:54 AM
  #61
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Originally posted by habenstein
Wyd, could you please post a link to the manufacturer site ( or site where you bought) those bulkhead braces and hubs???
Thanks.
I bought them off Ebay. I think they came from RCBoyz (seller)
wyd is offline
Old 01-26-2005, 07:47 AM
  #62
SpeedTech's Avatar
Hi Guys,
Just want to post a quick note in here that we are now carrying a full line of spare and hop-up parts for the Tamiya TNX
Click here to go straight to the TNX parts section
We also carrying a full line of Pro-line bodies, rims, and tires that will work with the TNX.
Steve Wang
SpeedTech is offline
Old 02-14-2005, 03:44 AM
  #63
habenstein's Avatar
Does anyone know whether the new, modified PL powerstroke shocks have a different part number to the regular ones that need modificaton to fit a tnx? thanks.
habenstein is offline
Old 02-19-2005, 08:31 PM
  #64
wyd
Tech Legend
wyd's Avatar
I have not seen any different part numbers for the Power Strokes. I think the T-Maxx ones are the ones everyone uses.
wyd is offline
Old 02-20-2005, 04:45 PM
  #65
Default proline shocks
Bro,
YOu could also try using front buggy shocks from Kyosho Kanai II or III versions. These are really good shocks for the TNX.
tinops is offline
Old 02-27-2005, 02:06 AM
  #66
habenstein's Avatar
Whats the deal with the Tnx Pro?
I think its a bit of a gimmick on Tamiyas behalf
but its got everything a racer needs and im eagerly
awaiting the price!
nice idea for the shocks btw
Old 02-27-2005, 07:42 PM
  #67
Default Headers
Wyd,
Have you tried headers for the TNX. Any headers that will fit? How about a novamega head of purple head of globe horizon? Any feedbacks if they improve temperature reduction and appearance??
tinops is offline
Old 02-27-2005, 07:46 PM
  #68
wyd
Tech Legend
wyd's Avatar
Default Re: Headers
Originally posted by tinops
Wyd,
I just run the stock header. I use White Lightning 20% fuel and have no problems with the motor running hot. It only runs around 220 to 230 and thats all the hotter it gets.
wyd is offline
Old 02-28-2005, 04:11 AM
  #69
wyd
Tech Legend
wyd's Avatar
Hey Jeff here is a few pics of our track.
wyd is offline
Old 02-28-2005, 04:12 AM
  #70
wyd
Tech Legend
wyd's Avatar
Another one.
wyd is offline
Old 02-28-2005, 04:13 AM
  #71
wyd
Tech Legend
wyd's Avatar
One more.
wyd is offline
Old 02-28-2005, 04:32 PM
  #72
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
I like the looks of those pics! We are able to run 1/10 nitro trucks at our local track but not the big trucks...lol
Thanks for your help.
Jeff
Jeff Werner is offline
Old 03-12-2005, 10:19 AM
  #73
SpeedTech's Avatar
Hi Guys,
We have the TNX Pro available for pre-order right now along with the estimated price for the truck. This is basically a replica of Dave Jun's truck from their successful last year of Monster Truck racing This truck should be available in the next couple of weeks
Steve Wang
Old 03-12-2005, 12:24 PM
  #74
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Man that's a great deal... $100 bucks for a set of Powerstrokes, wheels, tires and a cooling head.
Steve -- I got my Powerstrokes on. I just used the stuff that came in the hardware kit, along with the 3X15 socket heads for the lowers.
Basically, I drilled the upper mounting hole to use the thicker bolt, shortened the mounting boss to 1" overall length and used one of the white washers as a spacer on the side with the spring.
You have to do a bit of clearancing under the upper mounting boss to clear the larger shock cap. It would be pretty easy with a dremel, but I just used an X-acto knife. Same for the lower arms to clear the eyelet. That doesn't need much clearance at all.
Edit -- oh yeah...that and clearancing the lower end of the bypass shock. You can just grind/file on one side or cut the lower 3 fins off on a lathe. I rigged up a really simple arbor to to it in a lathe (-6 to 3/8 NPT AN fitting, a bolt, nut and some washers) and they came out just like the shocks in the Tamiya pics.
If anyone wants to get the shocks through Steve, I can cut them for you. He has the best prices around.
I'm on my way up to the park to beat on it.
Thanks for all your help Steve!!!
Turbo Joe is offline
Old 03-13-2005, 08:27 AM
  #75
madjack's Avatar
Trader Rating: 21 (100%+)
Post rear exhaust engine on the TNX?
Question for those who race the TNX. Has anyone swapped out the stock motor with a rear exhaust yet? (I was wondering what maifold, pipe and starting system were being used)
Thanks in advance,
John
madjack is offline
