battery options for ERBE
The specs for the e-revo state twin 2S LiPo (4S total) 14.8 volts 5000+ mAh minimum required. Or twin 3S (6S total) for 22.2 volts. There isn't much info on the traxxas site about this configuration. Can I use one 4S or one 6S pack or must it be 2 2S or 2 3S configuations because of the cabling? Does anyone know the dimensions of the battery box? Are there two boxes or do the packs go into one box? I'm thinking of switching from Flux HP to the E-Revo Brushless Edition.
Thanks.
Mark
Thanks.
Mark
There are two boxes, but if you can get a single pack mounted some how then a single 2s-6s is acceptable. The series connector is no trouble to mod or insert a small adapter on the other side.
I can't tell you the size of battery box, but the wiring config is identical to the flux.
