Not sure what to do. >
Old 04-19-2010, 04:03 PM
Unhappy Not sure what to do.
Fairly new to truck as I have been into planes most of my life. Bought a couple of T-Maxx's off a friend real cheap. Love the trucks run great and bash hard with little to no breakage. Ok problem is I bought a motor to build a truck with and kinda looking for some suggestions on what to do with it.
The motor is a GO B21
Bought a Maxx .21 Big Block extended chassis has not arrived in mail yet to see if it will fit.
Just looking for help or any ideas.
kyntar is offline
Old 04-19-2010, 04:36 PM
ALLSPEED's Avatar
If the engine is not a bump start only engine. You should not have any issues. The TMAXX is a damb good truck.
ALLSPEED is offline
Old 04-19-2010, 04:51 PM
It is a pull start. I should also add the motor is almost the same size of a maxx tire.
kyntar is offline
Old 04-19-2010, 06:37 PM
Trader Rating: 21 (100%+)
If it mounts on the engine mount you should get with the ext chassis, you've solved one prob. Depending on which Tmaxx you have and would use for donor parts, diffs and driveshifts may need upgrading. My 2.5 needed diffs and metal cvds after a Fantom 18 engine swap and I'm guessing your engine prob has more torque. Prob want a little stronger clutch as well.
Duster_360 is offline
Old 04-19-2010, 06:57 PM
ALLSPEED's Avatar
Yeah you should be O.K. then.
ALLSPEED is offline
HTML code is On
