What Tires Fir The Rulux Half Up's ? >
Old 04-06-2010, 09:28 AM
Justpassedu's Avatar
Trader Rating: 118 (100%+)
Default What Tires Fir The Rulux Half Up's ?
What tires fir the jconcept rulux half up's that are good for offroad and onroad ? I know of the badlands but is there anything else out there? Thankyou
Justpassedu is offline
Old 04-06-2010, 10:19 AM
Stubbs's Avatar
Trader Rating: 58 (100%+)
Most, if not all, LPR sized tires will fit the JC Half-ups.
A tire that works well on-road, and off-road.....good luck on that one. If it's hard enough to not wear down after the first run on asphalt, it's not likely to hook up worth a darn on dirt. Kind of like the tires on dual-purpose motorcycles....they don't great on either surface.
I'd suggest two sets of tires...one for dirt, and one for road.
Stubbs is offline
Old 04-06-2010, 10:43 AM
Maybe you could stretch some MT Mashers on. I've put Road Rages on halfups and it sure looked cool.
V0RT3X is offline
Old 04-06-2010, 12:01 PM
what are my lpr tire choice's ?
Old 04-06-2010, 12:32 PM
There are mostly racing tires available in LPR size which will wear fast onroad.
V0RT3X is offline
Old 04-06-2010, 06:41 PM
will these fit http://www3.towerhobbies.com/cgi-bin...9&I=LXLHD9&P=K , or will the masher fit ? and also can you dye a yellow rim black ? Thanks everyone
Old 04-08-2010, 08:23 PM
Trader Rating: 73 (100%+)
I've ran mashers on 1/2 ups. Makes for a nice setup. They don't have the off road traction of mulchers, but wear much better on pavement than the mulchers. Just remember to glue them against the inside bead on the wheel.
junkman12 is offline
HTML code is On
