Cracked manifold on revo 3.3 >
Old 02-27-2010, 10:55 AM
Default Cracked manifold on revo 3.3
Is there any cheap/good aftermarket ones?should i re weld it?
wantboost is offline
Old 02-27-2010, 10:58 AM
kgombe's Avatar
buy the traxxas platinum manifold... its spring loaded...
kgombe is offline
Old 02-27-2010, 11:31 AM
mudboger07's Avatar
Either that or buy the one for the os21tm, it wil lfit also and is spring loaded..
mudboger07 is offline
Old 02-27-2010, 01:35 PM
can i reweld it?
Old 02-27-2010, 02:25 PM
mudboger07's Avatar
Originally Posted by wantboost
can i reweld it?
No, it's cast alum, You'll be better of getting one that is held on by a spring, I went threw 2 manafolds in 2 days and desided to get the spring mount one and have never looked back...
Old 02-27-2010, 06:09 PM
MontanaMaxx's Avatar
you will waste more time trying to fix that just buying the spring header and there not that much 18 bucks
http://www3.towerhobbies.com/cgi-bin...&I=LXUTG4&P=ML
MontanaMaxx is offline
Old 02-27-2010, 10:11 PM
is this one the same? http://www.amainhobbies.com/product_...st-Header-Revo
Old 02-27-2010, 10:14 PM
kgombe's Avatar
NOOO.... its for a big block engine....but you can try and make it work with a small block inside the big block exhaust seal..
kgombe is offline
Old 02-28-2010, 05:29 AM
big block engine?
Old 02-28-2010, 10:24 AM
anything .21 and bigger is considered a big block what motor do you have?
Old 02-28-2010, 10:25 AM
here is the replacement to the stock header
http://www.amainhobbies.com/product_...Header-Tubular
Old 02-28-2010, 10:56 AM
3.3
Old 03-01-2010, 03:56 AM
so is the 3.3 big block?
Old 03-01-2010, 12:05 PM
Rampokker's Avatar
No, the 3.3 is a small block.
Rampokker is offline
Old 03-01-2010, 01:01 PM
yeah the 3.3 is small block it equates to a .19 i think or something close and there were some small block .21 i think the .21 tm is such motor but for the 3.3 get the spring header and your nightmares will be gone with your header
